- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Managing products
You can enable and disable products in Automation Suite at any point post-installation.
cluster_config.json
file stored in the
/opt/UiPathAutomationSuite
folder, and rerun the service
installer step.
cluster_config.json
file:
"actioncenter": {
"enabled": "true" //Set to "false" to disable the Action Center
"actioncenter": {
enable
flag and an SQL database.
sql_connection_string_template_odbc
in
cluster_config.json
, then the default database name
is AutomationSuite_Apps
sql_connection_str
inside the Apps field. This overrides the default database and connection string template set in sql_connection_string_template_odbc
cluster_config.json
file:
"apps": {
"enabled": "true" //Set to "false" to disable the Apps
"sql_connection_str": "" ////Optional and only require to override the default database name
"apps": {
enable
sql_connection_string_template_jdbc
in
cluster_config.json
, then the default AI Center
database name is AutomationSuite_AICenter
sql_connection_str
inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc
If AI Center does not require an external Orchestrator, see the following configuration details for enabling or disabling AI Center in
cluster_config.json
:"aicenter": { "enabled": "true", //Set to "false" to disable the AICenter "sql_connection_str": "" //Optional and only required to override the default database name }
"aicenter": { "enabled": "true", //Set to "false" to disable the AICenter "sql_connection_str": "" //Optional and only required to override the default database name } -
If AI Center requires an external Orchestrator, see the following configuration details for enabling or disabling AI Center in
cluster_config.json
:"aicenter": { "enabled": "true", //Set to "false" to disable the AI Center "sql_connection_str": "" //Optional and only required to override the default database name "orchestrator_url": "https://orchestrator.example.com", //Specify the Orchestrator URL for AI Center "identity_server_url": "https://orchestrator.example.com/identity", //Specify the Identiy URL for AI Center "orchestrator_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to the Orchestrator certificate "identity_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to Identity certificate file "metering_api_key": "test" //Specify the metering API key }
"aicenter": { "enabled": "true", //Set to "false" to disable the AI Center "sql_connection_str": "" //Optional and only required to override the default database name "orchestrator_url": "https://orchestrator.example.com", //Specify the Orchestrator URL for AI Center "identity_server_url": "https://orchestrator.example.com/identity", //Specify the Identiy URL for AI Center "orchestrator_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to the Orchestrator certificate "identity_cert_file_path": "/opt/UiPathAutomationSuite/UiPath_Installer/orch.cer", //Specify the path to Identity certificate file "metering_api_key": "test" //Specify the metering API key }Note:metering_api_key
is the Document Understanding or AI Units API key from the AI Center cloud account.
To complete the installation, run the following post-installation command:
./configureUiPathAS.sh aicenter configure --installation-token <identity token>
automation_hub
section of the cluster_config.json
file, set the enabled
flag
to true
"automation_hub": {
"enabled": "true" //Set to "false" to disable Automation Hub
"sql_connection_str": "" //Optional and only require to override the default database name
"automation_hub": {
enabled
flag to false
in the
automation_hub
file.
enable
in cluster_config.json
, then the default database name for
Automation Ops is AutomationSuite_Platform
sql_connection_str
inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template
cluster_config.json
"automation_ops": {
"enabled": "true", //Set to "false" to disable the Automation Ops
"automation_ops": {
To enable Automation Suite Robots, take the following steps:
Enable the
asrobots
flag in thecluster_config.json
file. If you want to enable package caching, make sure to properly configure thepackagecaching
andpackagecachefolder
flags as well.{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }
{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }Parameter
Default value
packagecaching
When set totrue
, robots use a local cache for package resolution.packagecachefolder
/uipath_asrobots_package_cache
The disk location on the serverless agent node where the packages are stored.
Note: Package caching optimizes your process runs and allows them to run faster. NuGet packages are fetched from the filesystem instead of being downloaded from the Internet/network. This requires an additional space of minimum 10GiB and should be allocated to a folder on the host machine filesystem of the dedicated nodes. -
If you use a multi-node HA-ready production setup, you must configure a specialized agent node for Automation Suite Robots. In single-node evaluation mode, an additional node is optional. For instructions, see Adding a dedicated agent node for Automation Suite Robots.
asrobots
flag in the cluster_config.json
file.
enable
, then the default database name is
AutomationSuite_DataService
sql_connection_str
inside the Data Service field. This overrides the default database and connection string template set in sql_connection_string_template
cluster_config.json
"dataservice": {
"enabled": "true", //Set to "false" to disable the Data Service,
"dataservice": {
enable
in
cluster_config.json
is AutomationSuite_DU_Datamanager
sql_connection_str
inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc
If you perform an offline installation, you need to download the offline bundle for Document Understanding as well. Before enabling Document Understanding, please refer to Install and Use Document Understanding.
cluster_config.json
"documentunderstanding": {
"enabled": "true", //Set to "false" to disable the Document Understanding
enable
AutomationSuite_Insights
sql_connection_str
inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template
enable_realtime_monitoring
flag to true
Insights has an optional SMTP configuration to enable receiving email notifications. Refer to Advanced installation experience for more details.
cluster_config.json
"insights": {
"enabled": "true", //Set to "false" to disable the Insights,
"enable_realtime_monitoring": "false", //Set to "true" to enable Insights Real-time monitoring,
"insights": {
orchestrator
flag to true
in
file.
"orchestrator": {
"enabled": "true" //Set to "false" to disable Orchestrator
"orchestrator": {
orchestrator
flag to false
in
file.
cluster_config.json
file:
- Enable the
processmining
flag. -
Configure the following connection string templates:
sql_connection_string_template_sqlalchemy_pyodbc
In multi-node HA-ready production installations, add a separate connection string for the second SQL Server. Note that in single-node evaluation installations, the seconds SQL Server is recommended. For instructions on how to configure the seconds SQL Server, see SQL requirements for Process Mining
"processmining": { "enabled": true, "sql_connection_str": "" // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }
processmining
flag.
enable
flag and an SQL Database.
AutomationSuite_Task_Mining
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads.
Before enabling Task Mining, please refer Task Mining installation section Adding a dedicated agent node for Task Mining.
cluster_config.json
"task_mining": {
"enabled": "true", //Set to "false" to disable the Task Mining,
"task_mining": {
Un-tainting for workloads
If desired, the Task Mining node can be repurposed as an agent node. To accomplish this, run the following commands:
- Check an actual taint using
kubectl describe node task-mining_nodename
command. - Run the command
kubectl taint nodes task-mining_nodename task.mining/cpu=present:NoSchedule-
. - Check taint has disappeared using
command.
enable
AutomationSuite_Test_Manager
sql_connection_str
inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template
cluster_config.json
"test_manager": {
"enabled": "true", //Set to "false" to disable the Test Manager,
"test_manager": {
cluster_config.json
, run the following command on the installer to update the service configuration:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --accept-license-agreement
- Step 1: Changing the product selection in the configuration file
- Enabling or disabling Action Center
- Enabling or disabling Apps
- Enabling or disabling AI Center
- Enabling or disabling Automation Hub
- Enabling or disabling Automation Ops
- Enabling or disabling Automation Suite Robots
- Enabling or disabling Data Service
- Enabling or disabling Document Understanding
- Enabling or disabling Insights
- Enabling or disabling Orchestrator
- Enabling or disabling Process Mining
- Enabling or disabling Task Mining
- Enabling or disabling Test Manager
- Step 2: Running the installer to update the new product configuration
