Last updated Jul 8, 2025
Converting an existing installation to multi-site setup
If you exited the Automation Suite setup, you can convert that into multi-site by taking the following steps:
  1. Convert the standalone Automation Suite cluster into the primary cluster. For details, see the following section.
  2. Install secondary Automation Suite cluster. For details, see Disaster Recovery - Installing the secondary cluster.
Converting a standalone cluster into a primary cluster
To convert an existing Automation Suite cluster into aprimary cluster of the multi-site deployment, take the following steps:
  1. Update cluster_config.json.
  2. Configure the infrastructure on the first server node.
  3. Configure the fabric and services on the first server node.
Updating cluster_config.json
Add or modify the required cluster_config.json parameters on the first server node. For more details, see the following documentation: Advanced installation experience
Note:
It is recommended to keep the FQDN of your existing Automation Suite setup to avoid reconfiguring all your robots.
Configuring the infrastructure on the first server node
  1. Navigate to the installer folder:
    cd /opt/UiPathAutomationSuite/{version}/installercd /opt/UiPathAutomationSuite/{version}/installer
  2. Run the following command on the first server node:
    uipathctl rke2 update-fqdn -i /path/to/cluster_config.json -o output.json --versions version.jsonuipathctl rke2 update-fqdn -i /path/to/cluster_config.json -o output.json --versions version.json
This will update all the other nodes in the cluster, including the remaining server nodes, agent nodes, and specialized agent nodes.
Configuring the fabric and services on the first server node
To configure the fabric and services on the first server node, run the following command:
./install-uipath.sh -i cluster_config.json -o output.json -k --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -k --accept-license-agreement
