- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Make sure to enable the following ports on your firewall for each source:
Port |
Protocol |
Source |
Purpose |
Requirements |
TCP |
Jump Server / client machine |
For SSH (installation, cluster management debugging) |
Do not open this port to the internet. Allow access to the client machine or jump server. |
TCP |
All nodes in a cluster and the load balancer |
For HTTPS (accessing Automation Suite) |
This port must have inbound and outbound connectivity from all the nodes in the cluster and the load balancer. |
TCP |
All nodes in a cluster |
etcd client port |
Do not open this port to the internet. Access between nodes must be ensured over a private IP address. |
TCP |
etcd peer port |
TCP |
For accessing Kube API using HTTPS, and required for node joining |
This port must have inbound and outbound connectivity from all the nodes in the cluster. |
UDP |
Required for Flannel (VXLAN) |
TCP |
All nodes in the cluster |
Used by Cilium for monitoring and handling pod crashes |
TCP |
For accessing Kube API using HTTPS, required for node joining |
This port must have inbound and outbound connectivity from all nodes in the cluster and the load balancer. |
TCP |
kubelet / metrics server |
TCP |
NodePort port for internal communication between nodes in a cluster |
The following additional ports are required in offline installations:
Port |
Protocol |
Source |
Purpose |
Requirements |
TCP |
Required for sending system email notifications |
Do not open this port to the internet. Access between nodes and the SMTP server must be ensured over a private IP address. |
TCP |
30070 1 |
TCP | The machine on which you plan to trigger the installation or upgrade. | For accessing the temporary registry during installation and upgrade using HTTP. | Traffic on this port must be forwarded to the Server Pool. |
30070
on the machine on which you plan to trigger the installation or upgrade.
Exposing port 6443 outside the cluster boundary is mandatory if there is a direct connection to the Kerberos API.
Port 9345 is used by nodes to discover existing nodes and join the cluster in the multi-node deployment. To keep the high availability discovery mechanisms running, we recommend exposing it via the load balancer with health check.
Additionally, make sure you have connectivity from all nodes to the SQL server. Do not expose the SQL server on one of the Istio reserved ports, as it may lead to connection failures.
If you have a firewall set up in the network, make sure that it has these ports open and allows traffic according to the aforementioned requirements.
