- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
In offline installations, you need a registry compliant with OCI (Open Container Initiative) to store the container images and deployment Helm charts. If you perform an online installation, skip this step.
We strongly recommend bringing your own registry. If you do not have one available, you can temporarily install an OCI-compliant registry on one of the server machines.
There are two ways to upload the Automation Suite artifacts to the external OCI-compliant registry:
- Option A: By mirroring your OCI-compliant registry with the UiPath® registry;
- Option B: By hydrating your OCI-compliant registry with the offline bundle.
The following table compares the two options to upload the artifacts to the registry so that you can choose the one that suits your needs:
Option A: Mirroring the registry |
Option B: Hydrating the registry |
Copies the artifacts from the UiPath® registry to any target registry. |
Uses the offline tarball to untar and upload the artifacts to the target registry. |
Requires Docker and Helm tools. |
Requires Podman and Helm tools. |
Requires internet access while copying the artifacts from the UiPath® registry to the target registry. |
Requires internet access only to download the offline tarball to the jump server. Uploading the tarball does not require internet access. |
Requires a temporary space to cache the images during the copying method. This space is usually configured during the Docker
installation. The default location is
/var/lib/docker .
Requires a temporary space to extract the tarball and a temporary space for Podman to load the images. Tarball extraction location must be provided during the hydration step. The Podman location can be
/var/tmp , which must have adequate storage available.
The required storage capacity for the
/var/lib/docker is around 128 GiB
The required storage capacity for the extraction is around 200 GiB, and
/var/tmp must be 256 GiB.
This method requires internet access on the jump machine from which you upload the Automation Suite artifacts onto your OCI-compliant registry.
Prerequisites for mirroring the UiPath® registry
To mirror the UiPath® registry, you need the following:
a VM running a Linux distribution (recommended) or a laptop (not recommended);
a Docker client authenticated with the private registry;
Helm 3.8 or newer authenticated with the private registry;
as-images.txt
as-helm-charts.txt
mirror-registry.sh
outbound connectivity to
registry.uipath.com
128 GiB of free disk space for Docker under the
/var/lib/docker
partition on the machine from which you upload the container images and charts.
Installing Docker and Helm
You must have Docker and Helm installed and authenticated on the machine from which you plan to upload the Automation Suite container images and charts to your registry.
To download the Docker binaries, see the official documentation.
To authenticate the Docker registry, see the official documentation. Alternatively, you can use the following command by replacing the sample credentials with your actual registry credentials:
docker login my.registry.io:443 --username "admin" --password "secret"
docker login my.registry.io:443 --username "admin" --password "secret" -
To download the Helm binaries, see the official documentation.
To authenticate the Helm registry, see the official documentation. Alternatively, you can use the following command by replacing the sample credentials with your actual registry credentials:
helm registry login my.registry.io:443 --username "admin" --password "secret"
Downloading as-images.txt
as-images.txt
, see Downloading installation bundles.
Downloading as-helm-charts.txt
as-helm-charts.txt
Downloading the optional Document Understanding bundles
To download the optional Document Understanding bundles, see Document Understanding documentation.
Downloading mirror-registry.sh
mirror-registry.sh
script, see Downloading the installation packages.
Uploading the Automation Suite images to your registry
mirror-registry.sh
script requires outbound connectivity to the source (default registry.uipath.com
) and target registries.
mirror-registry.sh
script does not perform authentication to the registry. It is assumed that you have already authenticated to the registry.
Flag |
Environment variable |
Description |
Mandatory. Path to the image manifest file. |
Mandatory. Path to the Helm chart manifest file. |
Mandatory. Pass the URL for the target registry. |
Optional. Pass the URL for the source registry; the default is
registry.uipath.com .
Ensure that we have the necessary permissions to execute the shell script, by running the following command:
chmod +x mirror-registry.sh
chmod +x mirror-registry.sh -
To upload the Automation Suite images to your registry, run the following command:
./mirror-registry.sh --target-registry-url my.registry.io:443 --source-registry-url registry.uipath.com --images-manifest /home/myuser/as-images.txt --helm-charts-manifest /home/myuser/as-helm-charts.txt
This method only requires internet access on the jump machine to download the offline bundle. Once the bundle is available, you can upload to your OCI-compliant registry without an internet connection.
This method may also require additional space on the machine to un-tar and upload to your registry. Aside from that, this method may take longer than the mirroring approach.
Prerequisites for hydrating the registry
To hydrate the registry, you need the following:
- a VM running a Linux distribution is preferred over running the script on a laptop;
- ability to download and copy or somehow propagate the offline bundle to the VM;
- Helm 3.8 or newer authenticated with the private registry;
- Podman installed, configured, and authenticated with the private registry;
- 150 GiB of free disk space for Podman under
/var/lib/containers
for loading the containers locally before pushing them to the remote registry. You can change the default path by updating the location of the graphRoot path in the output of thepodman-info
command. - Set the
TMP_DIR
environment variable as described in Podman official documentation. as.tar.gz
Installing Podman and Helm
You must ensure you have Podman and Helm installed and authenticated on the machine from which you plan to upload the Automation Suite container images and charts to your registry.
- To download the Podman binaries, see the official documentation.
- To authenticate to the Podman registry, see the official documentation. Alternatively, you can use the following command by replacing the sample credentials with your actual registry credentials:
podman login my.registry.io:443 --username "admin" --password "secret"
podman login my.registry.io:443 --username "admin" --password "secret" - To download the Helm binaries, see the official documentation.
- To authenticate the Helm registry, see the official documentation. Alternatively, you can use the following command by replacing the sample credentials with your actual registry credentials:
Downloading as.tar.gz
as.tar.gz
To download optional Document Understanding bundles, see Document Understanding documentation.
Downloading hydrate-registry.sh
hydrate-registry.sh
Uploading the Automation Suite images to the registry
hydrate-registry.sh
script.
hydrate-registry.sh
script does not require outbound connectivity except with the target registries.
hydrate-registry.sh
Flag |
Description |
Mandatory. Path to the offline bundle. |
The location to be used to untar the offline bundle. It can be either
/var/lib/containers or a custom location. Ensure you have a minimum of 100 GiB of storage. It is recommended to have 256 GiB of storage.
./hydrate-registry.sh --target-registry-url registry.azurecr.io --offline-bundle-path ./as.tar.gz --extract-path /extract/to/path
To properly configure your external OCI-compliant registry, you must update the trust store of all the machines on which you plan to install Automation Suite. For instructions on how to perfom this step post-installation, see Managing certificates.
To do that, take the following steps:
- Add the CA file to the
/etc/pki/ca-trust/source/anchors/
location. - Run
update-ca-trust
to update the trust store of the operating system. Once the trust store is updated, the extracted certificate file is merged in/etc/pki/ca-trust/extracted/ca-bundle.trust.crt
registry_ca_cert
parameter in the cluster_config.json
file. For details, refer to External OCI-compliant registry configuration.
This step is needed only for offline installations that use an in-cluster registry. You can skip this step if you perform an offline installation that uses an external OCI-compliant registry, or an online installation.
/uipath
mount point.
The temporary Docker registry is only required during installation or upgrade. Once the installation or upgrade is successful, the temporary registry is no longer needed and should be uninstalled.
To set up the temporary registry, you need the following:
as-fs.tar.gz
- to download it, see Downloading the installation packages.
To install the temporary Docker registry on one of the nodes, run the following command:
./configureUiPathAS.sh registry install-temp-registry -i cluster_config.json
Flag |
Description |
Optional. Accepts the path to the
cluster_config.json . It is only required when changing the default registry port and file path.
30070
and uses the /uipath/data/registry
file path. You must open port 30070
on the load balancer and the node on which you install the temporary docker registry.
The load balancer backend pool must exclusively target the nodes hosting the temporary docker registry.
cluster_config.json
file as shown in the following sample:
"infra": {
"tmp_docker_registry": {
"node_port": "<new port number>",
"file_path": "/uipath/data/registry"
"infra": {
After installing the temporary registry, take the following steps:
Hydrate the temporary registry with the container images and Helm charts by running the following command:
./configureUiPathAS.sh registry hydrate-temp-registry --offline-bundle /uipath/tmp/as-fs.tar.gz -i cluster_config.json
./configureUiPathAS.sh registry hydrate-temp-registry --offline-bundle /uipath/tmp/as-fs.tar.gz -i cluster_config.json - Seed the internal registry from the temporary registry by running the following command:
./configureUiPathAS.sh registry seed-internal-registry -i cluster_config.json
Flag |
Description |
File path containing the location of the
as-fs.tar.gz on your server node.
cluster_config.json file. It is only required when changing the default Docker registry port and file path.
- Uploading the Automation Suite artifacts to the external OCI-compliant registry
- Option A: Mirroring the UiPath® registry to your registry
- Option B: Hydrating the registry with the offline bundle
- Configuring the certificate for the external OCI-compliant registry
- Configuring the temporary Docker registry
- Prerequisites for setting the temporary registry
- Installing the temporary registry
- Hydrating the temporary registry
