Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Compatibility matrix
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
When migrating from standalone Orchestrator to Automation Suite, you must make sure the versions of standalone Orchestrator, UiPath.OrganizationMigrationApp, and Automation Suite are compatible.
The following table describes the version compatibility required to perform a migration to Automation Suite:
Standalone Orchestrator version | UiPath.OrganizationMigrationApp
version |
Automation Suite version |
2023.10.4 | 2023.10.4 | 2023.10.3 |
2023.10.3 | 2023.10.2 | 2023.10.2 |
2023.10.1 | 2023.10.1 | 2023.10.1 |
2023.10.0 | 2023.10.0 | 2023.10.0 |
Note:
How to read the table
For example, to migrate standalone Orchestrator 2023.10.0, you must use UiPath.OrganizationMigrationApp 2023.10.0, and ensure that you installed Automation Suite 2023.10.0.
