- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
before special characters.
To merge organizations in Automation Suite, run the following command:
./UiPath.OrganizationMigrationApp merge -i '<identity database connection of Automation Suite>' -o '<restored orchestrator DB in Automation Suite connection string>' -s '<list of organization IDs of the standalone product separated by comma, e.g. orgID1,orgID2>' -d '<list of organization IDs of Automation Suite separated by comma, e.g. orgID1,orgID2>'
Make sure to add
TrustServerCertificate=True
for both the source and destination SQL connections in the input. -
If you have multiple organization pairs to merge, make sure the organization ID sequence for the standalone product and the organization ID sequence for Automation Suite match.
./UiPath.OrganizationMigrationApp merge -i "<identity database connection of Automation Suite>" -o "<restored orchestrator DB in Automation Suite connection string>" -s "<list of organization IDs of the standalone product separated by comma, e.g. orgID1,orgID2>" -d "<list of organization IDs of Automation Suite separated by comma, e.g. orgID1,orgID2>"
for both source and destination SQL connection strings in the input.
When running the UiPath.OrganizationMigrationApp tool, you must provide the following details:
The list of organization IDs for the standalone product
The list of organization IDs for Automation Suite
Make sure to use the same organization IDs as the ones identified in Step 1: Moving the Identity organization data from standalone to Automation Suite.
Condition |
Does the source user has an email address? |
Does the target user has an email address? |
Is the source user email the same as the one of the target user? |
Is the source username the same as the target username? |
Result |
1 |
The source user is moved to the target organization; the target organization user has access to standalone Orchestrator. |
2 |
The source user is moved to the target organization; the target organization user has access to standalone Orchestrator. After the merge, two users have the same username, and they must use the email address to login. |
3 |
or |
The source user is merged with the target user; the target user has access to standalone Orchestrator. |
4 |
N/A |
5 |
N/A |
6 |
N/A |
7 |
N/A |
You must manually configure the email address for the target user or remove the target user. If you configure the email address, the source user is merged with the target user, and the target user has access to standalone Orchestrator. If you remove the target user, the source user is moved to the target organization, and the target organization user has access to standalone Orchestrator. |
8 |
N/A |
The source user is moved to the target organization, and the target organization user has access to standalone Orchestrator. |
9 |
N/A |
You must configure the email address to be empty for the target user or remove the target user. If you configure the email address as empty, the source user is merged with the target user, and the target user has access to standalone Orchestrator. If you remove the target user, the source user is moved to the target organization, and the target organization user has access to standalone Orchestrator. |
If the source and target robot usernames are the same, the source robot user is appended the user ID and is move to the target organization.
Source robot username |
Target robot username |
Moved source robot username |
sameRobot |
sameRobot |
If the source and target robot group names are the same, the source robot user is appended a string and is moved to the target organization.
Source group name |
Target group name |
Moved source group username |
sameGroup |
sameGroup |
If the organization merge failed, check the logs. Depending on whether the Identity or the Orchestrator migration failed, take the following steps:
If the Identity migration failed, you can just fix the error and execute the organization merge command again. This would rollback all the changes since we have set a transaction for operations for Identity.
If the Orchestrator migration failed, the Orchestrator database would roll back, but the Identity database would not rollback. As a result, you must restore the backup of the Identity database and replace the connection string to use the new database. After fixing the error, run organization merge command again.
If the Orchestrator migration failed, take the following steps:
Restore the backup of the Identity database.
Right-click the database directory and select Import Data-tier Application.
Select the backup database file.
Input the backup database name.
Wait for the process to complete.
Replace the identity connection string.
`"platform": { "sql_connection_str": "<dotnet connection string>", (added line) "enabled": true, },`
`"platform": { "sql_connection_str": "<dotnet connection string>", (added line) "enabled": true, },` -
Fix the error and use the new platform connection string to run the merge command again.
