- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Failed status when trying to deploy an ML skill
If you are trying unsuccesfully to deploy a Document Understanding ML Skill on AI Center, check the solutions below.
If you are installing the Automation Suite offline, please double check if the Document Understanding bundle has been downloaded and installed.
The bundle includes the base image (e.g., model library) for the models to properly run on AI Center after uploading the ML Packages via AI Center UI.
For details about installing Document Understanding bundle, please refer to the documentation and . To add Document Understanding bundle, please follow the documentation to re-run the Document Understanding bundle installation.
modulenotfounderror: no module named 'ocr.release'; 'ocr' is not a package
When creating a Document Understanding OCR ML Package in AI Center, keep in mind that it cannot be named ocr or OCR, which conflicts with a folder in the package. Please make sure to choose another name.
Failed to list deployment
or Unknown Error
when deploying the model for the first time.
The workaround is to try deploying the model again. The second time, the deployment is be faster as most of the deployment work of image building would have been done during the first attempt. Document Understanding ML Packages take around 1-1.5 hours for deploying the first time, and these are faster when deploying them again.
