- Overview
- Glossary
- Automation Suite products
- Cross-product dependencies
- Supported use cases for single-node and multi-node installations
- Multi-node architecture and design consideration
- Cross-deployment feature comparison
- Security and compliance
- Certificates overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Why the single-node mode is only suitable for evaluation purposes, whereas the multi-node profile can be implemented in production.
Automation Suite supports two deployment modes, each targeted at specific use cases, as explained in the following table:
Deployment mode |
Description |
Single-node — evaluation |
Supported only for evaluation and demo scenarios. |
Multi-node — production, HA-enabled |
The only configuration supported for production deployments. You can perform additional configuration post-deployment to have full HA capabilities. |
Automation Suite uses a cloud native architecture based on Kubernetes. It provides all the benefits in scale, automatic resource management, and reliability that come with Kubernetes.
To offer these benefits, the Kubernetes design is based on the following fundamental aspects:
- Running on an uneven number of multiple machines (3, 5, 7, etc.);
- Using the quorum principle to handle independent node failures and data corruption. For a cluster of N machines, as long as there is still a number of N/2 + 1 machines that have quorum, the cluster is functional and can recover gracefully with no observed failures.
By definition, single-node deployments do not benefit from the previously described characteristics and are not supported for production deployments. Failures and data loss can and will occur.
However, since support for single-node deployments is valuable for evaluation and demo scenarios, UiPath® offers this deployment option applicable to some specific use cases.
