- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Configuring the FQDN post-installation
- Setting up Kerberos authentication
- Setting up Elasticsearch and Kibana
- Forwarding application logs to Splunk
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
This section covers exporting POD logs. For exporting robot logs, see Ochestrator - About Logs.
Splunk is an external tool, and UiPath® does not have an opinion on how you should configure your Splunk setting. For more details about HTTP Event Collector, see Splunk official documentation.
The Splunk-Fluentd stack is a centralized logging solution that allows you to search, analyze, and visualize log data. Fluentd collects and sends the logs to Splunk. Splunk retrieves the logs and lets you visualize and analyze the data.
To configure Splunk, take the following steps:
- Click Settings in the top navigation bar, and then select Indexes.
- Click New Index and then Create an index.
- Click Settings in the top navigation bar, and then select Data inputs.
- Click HTTP Event Collector.
- To enable the new token creation, click Global Settings .
- Enable and save the Global Settings.
- To create the token, click New Token.
- Enter a name for the HTTP Event Collector and click Next.
- Click New and enter Source Type details.
- Scroll down and select Index from the available list of indexes, and click Next in the top navigation bar.
- Verify the data and click Submit.
- Once created, fetch the details of Token ID,Index,Source,Source Type. You need these values to set up ClusterOutput.
Create a Kubernetes secret with the HTTP Event Collector (HEC) token generated in the Splunk UI. This token is used for the authentication between Automation Suite and Splunk.
kubectl -n cattle-logging-system create secret generic splunk-hec-token --from-literal=splunk_hec_token=<splunk_hec_token>
ClusterOutput
defines where your logs are sent to and describes the configuration and authentication details.
To configure the ClusterOutput for Splunk, run the following command:
kubectl -n cattle-logging-system apply -f - <<"EOF"
apiVersion: logging.banzaicloud.io/v1beta1
kind: ClusterOutput
metadata:
spec:
splunkHec:
buffer:
tags: '[]'
timekey: <splunk_hec_timekey>
timekey_use_utc: true
timekey_wait: 10s
type: file
hec_host: <splunk_hec_host>
hec_port: <splunk_hec_port>
hec_token:
valueFrom:
secretKeyRef:
key: splunk_hec_token
index: <splunk_hec_index>
insecure_ssl: true
protocol: <splunk_hec_protocol>
source: <splunk_hec_source>
sourcetype: <splunk_hec_source_type>
EOF
kind: ClusterOutput
metadata:
spec:
splunkHec:
buffer:
tags: '[]'
timekey_wait: 10s
type: file
hec_token:
valueFrom:
secretKeyRef:
insecure_ssl: true
EOF
with the corresponding values used in your Splunk configuration. For details, see the following table:
Attribute |
Description |
The network host of your Splunk instance. This is usually the IP address or FQDN of Splunk. |
The Splunk port for client communication. This port usually differs from the port on which you launch the Splunk dashboard.
The conventional HEC port for Splunk is
8088 .
The secret key of the Splunk token. This is the name of the key in the secret you created in the previous step, which holds Splunk HEC token. The presented manifest already contains the key:
splunk_hec_token . If you have not altered the command to create a secret, you do not need to change this value.
splunk_hec_timekey value in splunkHec.buffer |
The output frequency, or how often you want to push logs. We recommend using a 30-seconds (
30s ) interval.
The URL protocol. Valid values are
http and https . You must use HTTPS protocol if you have SSL communication enabled on Splunk.
The identifier for the Splunk index. Used to index events. |
The source field for events. |
The source type field for events. |
The following example is based on the configuration presented on this page.
ClusterFlow
to define:
- the logs you want to collect and filter;
- the
ClusterOutput
to send the logs to.
To configure ClusterFlow in Fluentd, run the following command:
kind: ClusterFlow
metadata:
namespace: cattle-logging-system
spec:
filters:
- tag_normaliser:
format: ${namespace_name}/${pod_name}.${container_name}
globalOutputRefs:
- splunk-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- aicenter-hit-count-update
- istio-configure-executor
- on-prem-tenant-license-update
- curl
- recovery
- aicenter-oob-scheduler
- cert-trustor
- exclude:
namespaces:
- fleet-system
- cattle-gatekeeper-system
- default
- exclude:
labels:
app: csi-snapshotter
- exclude:
labels:
app: csi-resizer
- select: {}
EOF
kind: ClusterFlow
metadata:
spec:
filters:
- tag_normaliser:
globalOutputRefs:
- splunk-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- curl
- recovery
- cert-trustor
- exclude:
namespaces:
- fleet-system
- default
- exclude:
labels:
- exclude:
labels:
app: csi-resizer
- select: {}
EOF
If, for some reason, the application logs are not pushed to Splunk, take the following steps:
- Change the Fluentd log level to debug.
- Query the Fluentd
pod:
kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"add","path":"/spec/fluentd/logLevel","value":debug}]' kubectl -n cattle-logging-system exec -it sts/rancher-logging-root-fluentd cat /fluentd/log/out
kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"add","path":"/spec/fluentd/logLevel","value":debug}]' kubectl -n cattle-logging-system exec -it sts/rancher-logging-root-fluentd cat /fluentd/log/outNote: The Fluentd logs should indicate the cause of data not being pushed to Splunk. - After fixing the issue, restore the Fluentd log
level:
kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"remove","path":"/spec/fluentd/logLevel"}]'
