Automation Suite
- Overview
- Glossary
- Automation Suite products
- Cross-product dependencies
- Cross-deployment feature comparison
- Security and compliance
- Certificates overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
This table compares the feature availability across the following deployment methods:
- the AWS, Azure, and GCP cloud templates, which provision the infrastructure and install Automation Suite in a short amount of time. Templates are the recommended option.
the manual installation provisioning method, which requires more technical expertise and is considerably more time-consuming.
Feature
AWS template
Azure template
GCP template
Manual installation provisioning
Deploy to existing Virtual Network
Single-node evaluation vs. multi-node HA-ready production
Can set number of instances
Air-gapped
A-la-carte product selection
Custom domain (cloud-provided DNS service or not)
Custom certificates
Deploy to existing SQL Server
Hardware requirements validation
Template uses cloud-native availability zones
N/A
Proxy configuration
Optional bastion host
N/A
Instance refresh
N/A
Backup and restore cluster
N/A
Remove nodes
N/A
