- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Saving robot logs to an Elasticsearch server can be achieved through two types of configuration: basic and advanced.
The basic configuration provides default functionality that activates the preconfigured Elasticsearch NLog target, which is made up of an Elasticsearch target wrapped in a Buffering target. This type of configuration is enough in most scenarios.
However, if you need to further customize the rules, you can use the advanced configuration method.
To apply the basic configuration, take the following steps. For more details, see Configuring the Orchestrator parameters.
The basic configuration supports Elasticsearch version 7.x. For Elasticsearch 8.x, you need to use the advanced configuration.
NLog.config
target.
- Follow the basic configuration steps described above.
- Follow the Advanced NLog configuration steps, then update the
robotElasticBuffer
target with the properties that need to be changed.
The advanced configuration also supports Elasticsearch version 8.x.
nlog.config.json
for Elasticsearch 7.x
"Nlog": {
"targets": {
"robotElasticBuffer": {
"flushTimeout": 1000,
"bufferSize": 1000,
"slidingTimeout": false,
"target": {
"uri": "https://elastic.example.com:9200",
"requireAuth": true,
"username": "elastic-user",
"password": "elastic-password",
"index": "${event-properties:item=indexName}-${date:format=yyyy.MM}",
"documentType": "logEvent",
"includeAllProperties": true,
"layout": "${message}",
"excludedProperties": "agentSessionId,tenantId,indexName"
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
nlog.config.json
for Elasticsearch 8.x
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
"documentType": "",
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
"documentType": "",
