- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
The Automation Suite diagnostics tool runs a set of checks to generate a report on the cluster health, which you can analyze to identify issues and their potential root causes. The tool helps you find common issues, such as lost database connectivity or invalid or expired credentials.
uipathctl
and
uipathtools
, which you can
download on your management machine.
uipathtools
is a CLI tool that contains a subset of uipathctl
capabilities specific to health commands. The tool is backwards compatible and works with any of the supported Automation
Suite versions. We recommend using uipathtools
as the first step if you face any issue.
check
and test
commands provide quick insights into the state of the cluster without running a deep analysis.
check
relies on the ArgoCD health and sync status and does not modify any state in the cluster -
test
looks into the applications, deployment, or pods and temporarily mutates the state of the cluster to provide you with those insights.
To run a health check, use one of the following commands, depending on the CLI tool you use:
- If you use
uipathctl
, run:./uipathctl health check
./uipathctl health check - If you use
uipathtools
, run:./uipathtools health check
Sample output of the generated report:
Checks run on cluster/
✔ [NOTIFICATIONSERVICE]
✔ [NOTIFICATIONSERVICE_HEALTH] Application is healthy and in sync
✔ [ACTION_CENTER]
✔ [ACTIONCENTER_HEALTH] Application is healthy and in sync
❌ [SYNC]
❌ [namespace:"argocd" | kind:"Application" | name:"dataservice"] Application health check failed: health status is Progressing and sync status is Synced
✔ [RELOADER]
✔ [RELOADER_HEALTH] Application is healthy and in sync
❌ [POD]
✔ [LIST_NAMESPACES] Retrieved 25 namespaces to check pod health
❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-v5krg cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-xs9t5 cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-taskrunner-787df76c74-98h5l cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
✔ [ISTIO]
✔ [LIST_PODS] Found 2 pods for Istio
✔ [ISTIOD_EXISTS] The Istio pods are present and running version -
✔ [ISTIOD_READY] Istio pods are healthy
✔ [AIEVENTS]
✔ [AIEVENTS_HEALTH] Application is healthy and in sync
❌ [DATASERVICE]
❌ [DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced
✔ [PLATFORM]
✔ [PLATFORM_HEALTH] Application is healthy and in sync
✔ [TASK_MINING]
✔ [TASKMINING_HEALTH] Application is healthy and in sync
✔ [LOGGING]
✔ [LOGGING_HEALTH] Application is healthy and in sync
✔ [WEBHOOK]
✔ [WEBHOOK_HEALTH] Application is healthy and in sync
✔ [ACTION_CENTER]
❌ [SYNC]
✔ [RELOADER]
❌ [POD]
✔ [ISTIO]
✔ [AIEVENTS]
❌ [DATASERVICE]
✔ [PLATFORM]
✔ [TASK_MINING]
✔ [LOGGING]
✔ [WEBHOOK]
command checks the health of all the
components. However, it also allows you to check strictly the components that you are
interested in:
- If you want to exclude components from the execution, use the
--excluded
flag. For example, if you do not want to check the health of SQL, runuipathctl health check --excluded SQL
. The command checks the health of all components except for SQL. - If you want to include only certain components in the execution, use the
--included
flag. For example, if you only want to check the health of DNS and objectstore, runuipathctl health check --included DNS,OBJECTSTORAGE
Analyzing the logs
- After running a check health check, the logs show that health check for the Data Service application failed.
❌ [DATASERVICE] ❌ [DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced
❌ [DATASERVICE] ❌ [DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced - After further investigation, it becomes clear that the Data Service application failed because the
anddataservice-taskrunner-787df76c74-98h5l
pods are in a failed state. If you analyze further, you can find that the missingdataservice-external-storage-secret
is missing.❌ [POD] ✔ [LIST_NAMESPACES] Retrieved 25 namespaces to check pod health ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-v5krg cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-xs9t5 cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-taskrunner-787df76c74-98h5l cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
❌ [POD] ✔ [LIST_NAMESPACES] Retrieved 25 namespaces to check pod health ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-v5krg cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-xs9t5 cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-taskrunner-787df76c74-98h5l cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found - To fix this issue, ensure that you provided the
correct credentials for the objectstore in the
input.json
To run a health test, use one of the following commands, depending on the CLI tool you use:
- If you use
uipathctl
, run:./uipathctl health test
./uipathctl health test - If you use
uipathtools
, run:./uipathtools health test
✔ [GATEKEEPER]
✔ [CREATE_CONSTRAINT] Created test constraint
✔ [VERIFY] Constraint verified
✔ [CLEANUP] Cleaned up the test constraint
✔ [ACTION_CENTER]
✔ [CREATE_NAMESPACE] Created namespace prereqk6b72
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqk6b72
✔ [CREATE_NAMESPACE] Created namespace prereqbxjx8
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqbxjx8
✔ [CREATE_NAMESPACE] Created namespace prereq8zvw4
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq8zvw4
✔ [DATASERVICE]
✔ [CREATE_NAMESPACE] Created namespace prereqxwlsb
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqxwlsb
✔ [CREATE_NAMESPACE] Created namespace prereq5szsn
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq5szsn
✔ [APPS]
✔ [CREATE_NAMESPACE] Created namespace prereq9z6nb
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq9z6nb
✔ [CREATE_NAMESPACE] Created namespace prereq6v7lm
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq6v7lm
✔ [CREATE_NAMESPACE] Created namespace prereqxxn5v
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqxxn5v
✔ [AUTOMATION_HUB]
✔ [CREATE_NAMESPACE] Created namespace prereq4jkbt
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq4jkbt
✔ [TEST_MANAGER]
✔ [CREATE_NAMESPACE] Created namespace prereqnvvpc
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqnvvpc
✔ [ORCHESTRATOR]
✔ [CREATE_NAMESPACE] Created namespace prereq8pf2f
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq8pf2f
✔ [CREATE_NAMESPACE] Created namespace prereq4w4v4
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq4w4v4
✔ [CREATE_NAMESPACE] Created namespace prereqkzwqg
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqkzwqg
✔ [INSIGHTS]
✔ [CREATE_NAMESPACE] Created namespace prereqqmgjc
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqqmgjc
✔ [CREATE_NAMESPACE] Created namespace prereq4vnjx
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq4vnjx
✔ [CREATE_NAMESPACE] Created namespace prereqgtg9g
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqgtg9g
✔ [AUTOMATION_OPS]
✔ [CREATE_NAMESPACE] Created namespace prereqgkkrz
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqgkkrz
✔ [AICENTER]
✔ [CREATE_NAMESPACE] Created namespace prereqdls88
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqdls88
✔ [CREATE_NAMESPACE] Created namespace prereq6m7x9
✔ [CREATE_POD] Created test pod curl-pod in namespace prereq6m7x9
✔ [GATEKEEPER]
✔ [ACTION_CENTER]
✔ [DATASERVICE]
✔ [APPS]
✔ [AUTOMATION_HUB]
✔ [TEST_MANAGER]
✔ [ORCHESTRATOR]
✔ [INSIGHTS]
✔ [AUTOMATION_OPS]
✔ [AICENTER]
command executes health tests on all the
interested in:
--excluded
flag. For example, if you do not want to check the health of SQL, runuipathctl health test --excluded SQL
--included
flag. For example, if you only want to check the health of DNS and objectstore, runuipathctl health test --included DNS,OBJECTSTORAGE
check
and test
commands for the Data Service application, you can see that the former validates the health of the application, whereas the
latter checks the routing.
Known issue
You might get an error message similar to the following sample. You can ignore it as no action is required from your side.
E0621 23:32:56.426321 24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.426392 24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.444420 24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.446150 24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.513357 24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
diagnose
command provides deep insights into the state of the cluster. It helps you identify issues at all levels, such as SQL, objectstore,
node, secret, Istio, metworking etc.
- It covers both the
check
andtest
commands. - It runs the prerequisites checks performed before the Automation suite installation, to validate changes to the environment configuration that were made post-installation and that can be the potential cause of the issue.
It runs on the all the nodes to gather any node-specific issues, such as resource unavailability, any network interference, etc.
To run a diagnostic check, use one of the following commands, depending on the CLI tool you use:
- If you use
uipathctl
, run:./uipathctl health diagnose input.json --versions version.json
./uipathctl health diagnose input.json --versions version.json - If you use
uipathtools
, run:./uipathtools health diagnose input.json --versions version.json
Checks run on nodes/aks-pool0-27031798-vmss000001
✔ [REDIS(PORT=6380)]
✔ [CONNECTIVITY] Successfully made Redis connection on ci-asaks4011056.redis.cache.windows.net:6380
✔ [OBJECTSTORAGE(PRODUCT=ORCHESTRATOR)]
✔ [CHECK_API] Object storage test passed for orchestrator
✔ [SQL(PRODUCT=PROCESSMINING, TYPE=ADO)]
✔ [EXECUTE_NATIVE] Successfully executed command
✔ [BUILD_CLIENT] Successfully built ADO client
✔ [CONNECT] Successfully connected ADO client to DB
✔ [DB_ROLES] SQL user has the required roles to DB
✔ [DNS(FQDN=INSIGHTS.<FQDN>)]
✔ [VALIDATE_FQDN] FQDN is valid
✔ [RESOLVE_SUBDOMAIN] Resolved insights.ci-asaks4011056.infra-sf-ea.infra.uipath-dev.com to [{20.71.155.129 }]
✔ [IPS_MATCH] Subdomain resolves to top domain
✔ [DNS(FQDN=ALM.<FQDN>)]
✔ [RESOLVE_SUBDOMAIN] Resolved alm.ci-asaks4011056.infra-sf-ea.infra.uipath-dev.com to [{20.71.155.129 }]
✔ [NODE]
✔ [NODE_EXISTS] 12 Nodes present in the cluster
✔ [NODE_READY] All the nodes are in ready state
✔ [GATEKEEPER]
✔ [GATEKEEPER_HEALTH] Application is healthy and in sync
✔ [LOGGING]
✔ [DATASERVICE]
✔ [CREATE_NAMESPACE] Created namespace prereqctzhp
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqctzhp
✔ [ROBOTUBE]
✔ [ROBOTUBE_HEALTH] Application is healthy and in sync
✔ [AIRFLOW]
✔ [AIRFLOW_HEALTH] Application is healthy and in sync
✔ [ARGOCD]
✔ [ARGOCD_SERVER_PODS] Component argocd-server has ready Pods
✔ [ARGOCD_REPO_SERVER_PODS] Component argocd-repo-server has ready Pods
✔ [ARGOCD_APP_CONTROLLER_PODS] Component argocd-application-controller has ready Pods
✔ [ARGOCD_REDIS_PODS] Component redis-ha has ready Pods
✔ [ISTIO]
✔ [AICENTER]
✔ [AICENTER_HEALTH] Application is healthy and in sync
✔ [CREATE_NAMESPACE] Created namespace prereqn6sqn
✔ [CREATE_POD] Created test pod curl-pod in namespace prereqn6sqn
Checks run on local/
✔ [CONNECTIVITY]
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-4rffj on aks-pool0-27031798-vmss000002 can reach echo-a-4rffj's IP 10.240.1.86 on aks-pool0-27031798-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-4rffj on aks-pool0-27031798-vmss000002 can reach echo-a-8c6t5's IP 10.240.3.57 on aks-pool3-27031798-vmss000000
✔ [POD_TO_A] Scenario: http check between two random pods completed successfully
✔ [POD_TO_B_MULTI_NODE_CLUSTERIP] Scenario: http check between from pod to a multinode ClusterIP completed successfully
✔ [POD_TO_B_MULTI_NODE_HEADLESS] Scenario: http check between from pod to a multinode ClusterIP without a clusterIP set completed successfully
✔ [POD_TO_B_INTRA_NODE_CLUSTERIP] Scenario: http check between from two pods colocated on the same node via ClusterIP completed successfully
✔ [INGRESS]
✔ [INGRESS_GATEWAY_FOUND] Found service istio-ingressgateway in the cluster
✔ [INGRESS_GATEWAY_PORT_CHECK] Service istio-ingressgateway is configured to allow traffic on http://ci-asaks4011056.infra-sf-ea.infra.uipath-dev.com
✔ [INGRESS_GATEWAY_PORT_CHECK] Service istio-ingressgateway is configured to allow traffic on https://ci-asaks4011056.infra-sf-ea.infra.uipath-dev.com:443
✔ [OSS(COMPONENT=MONITORING)]
✔ [OSS(component=monitoring)] Check for component monitoring passed
✔ [OSS(COMPONENT=GATEKEEPER)]
✔ [OSS(component=gatekeeper)] Check for component gatekeeper passed
✔ [STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA)]
✔ [STORAGE_CLASS_EXISTS] Storage class azurefile-csi exists
✔ [LIST_NODES] Listed 12 nodes
✔ [CREATE_NAMESPACE] Created namespace prereqhcpkc
✔ [CREATE_STATEFULSET] Created statefulset storage-class-check-5n272
✔ [LIST_PODS] Listed 1 pods on node aks-pool3-27031798-vmss000001
✔ [POD_RUNNING] Found one pod running on node aks-pool3-27031798-vmss000001
✔ [REGISTRY]
✔ [CONNECTIVITY] Successfully made Registry connection on sfbrdevhelmweacr.azurecr.io
✔ [NETWORK-POLICIES]
✔ [CREATE_NAMESPACE] Namespace prereqw4t9b created
✔ [CREATE_EGRESS_NETWORK_POLICY] Created the egress network policies allow-coredns-egress and block-external-traffic
✔ [CREATE_INGRESS_NETWORK_POLICY] Created the ingress network policy: block-echo-server-ingress
✔ [CREATE_SERVICE] Service echo-server-svc created
✔ [STORAGECLASS(NAME=STORAGE_CLASS)]
✔ [STORAGE_CLASS_EXISTS] Storage class managed-premium exists
✔ [CREATE_NAMESPACE] Created namespace prereqgjhcb
✔ [CREATE_STATEFULSET] Created statefulset storage-class-check-nm9th
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27031798-vmss000003
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27031798-vmss000003
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27031798-vmss000001
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27031798-vmss000001
✔ [RESOLVE_TOP_DOMAIN] Resolved ci-asaks4011056.infra-sf-ea.infra.uipath-dev.com to [{20.71.155.129 }]
✔ [NODE(CPU >= 8, RAM >= 16GI)]
✔ [AT_LEAST_ONE_NODE] At least one node found
✔ [CPU_USAGE] Node aks-pool0-27031798-vmss000000 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27031798-vmss000000 has 38.27% memory usage
✔ [POD_USAGE] Node aks-pool0-27031798-vmss000000 has 40.00% of pods in use. Number of pods: 40.00 max allowed: 100.00
✔ [OSS(COMPONENT=CERT-MANAGER)]
✔ [OSS(component=cert-manager)] Check for component cert-manager passed
✔ [RESOURCE]
✔ [Capacity] Automation suite already installed on cluster
✔ [OSS(COMPONENT=LOGGING)]
✔ [OSS(component=logging)] Check for component logging passed
✔ [GPU(PRODUCT=DOCUMENTUNDERSTANDING)]
✔ [BASIC_GPU_SUCCESS] Was able to start a CUDA job on a GPU node
❌ [DATASERVICE]
❌ [ISTIO]
✔ [ISTIO_SYNC_STATUS] Istio sync is up-to-date
❌ [ISTIO_ENVOY_CONFIG_STATUS] Istio Envoy configs are not healthy: Error [IST0101] (VirtualService uipath/du-platform-vs) Referenced host:port not found: "aistorage:5000"
✔ [ISTIO_SERVICEMESH_VALIDATION_GET_REGISTRY_FQDN] Successfully retrieved registry url
✔ [ISTIO_SERVICEMESH_VALIDATION_GET_CLUSTER_FQDN] Successfully retrieved cluster fqdn
✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_DEPLOYMENT] Successfully created the test deployment istio-validation-deployment
✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_SERVICE] Successfully created the test service istio-validation-service
✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_GATEWAY] Successfully created the test gateway istio-validation-gateway
✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_VIRTUALSERVICE] Successfully created the test virtual service istio-validation-vs
✔ [ISTIO_SERVICEMESH_VALIDATION_URL_ACCESS] Success exposing the service via servicemesh
❌ [POD]
❌ [CANNOT_MOUNT_VOLUME] Pod uipath/ah-tenant-service-sync-insights-data-job-28122960-p6rzg cannot mount volume: MountVolume.SetUp failed for volume "ah-insights-secrets" : failed to sync secret cache: timed out waiting for the condition
❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-v5krg cannot mount volume: (combined from similar events): Unable to attach or mount volumes: unmounted volumes=[external-storage-creds], unattached volumes=[workload-socket is-secrets openssl istio-podinfo temp-location cert-location istio-data external-storage-creds workload-certs istio-envoy java domain-cert-config edk2 credential-socket tmp additional-ca-cert-config pem istiod-ca-cert istio-token app-secrets ceph-storage-creds]: timed out waiting for the condition
❌ [POD_UNHEALTHY] Latest event for pod uipath/du-documentmanager-dm-maintenance-cron-28122960-4sm5z: Error: failed to sync configmap cache: timed out waiting for the condition
❌ [SYNC]
✔ [NODE]
✔ [GATEKEEPER]
✔ [LOGGING]
✔ [DATASERVICE]
✔ [ROBOTUBE]
✔ [AIRFLOW]
✔ [ARGOCD]
✔ [ISTIO]
✔ [AICENTER]
✔ [CONNECTIVITY]
✔ [INGRESS]
✔ [REGISTRY]
✔ [RESOURCE]
❌ [DATASERVICE]
❌ [ISTIO]
❌ [POD]
❌ [SYNC]
diagnose
command runs at multiple levels, such as infrastructure, networking, storage, pods, DNS etc.
Analyzing the logs
There are two potential issues that you can be notice in the previous logs:
- Istio has a bad configuration, which can cause
issues accessing the Document Understanding platform:
❌ [ISTIO] ✔ [ISTIO_SYNC_STATUS] Istio sync is up-to-date ❌ [ISTIO_ENVOY_CONFIG_STATUS] Istio Envoy configs are not healthy: Error [IST0101] (VirtualService uipath/du-platform-vs) Referenced host:port not found: "aistorage:5000"
❌ [ISTIO] ✔ [ISTIO_SYNC_STATUS] Istio sync is up-to-date ❌ [ISTIO_ENVOY_CONFIG_STATUS] Istio Envoy configs are not healthy: Error [IST0101] (VirtualService uipath/du-platform-vs) Referenced host:port not found: "aistorage:5000" - Data Service is unavailable. See Ceph in the code
example.
❌ [DATASERVICE] ❌ [DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-v5krg cannot mount volume: (combined from similar events): Unable to attach or mount volumes: unmounted volumes=[external-storage-creds], unattached volumes=[workload-socket is-secrets openssl istio-podinfo temp-location cert-location istio-data external-storage-creds workload-certs istio-envoy java domain-cert-config edk2 credential-socket tmp additional-ca-cert-config pem istiod-ca-cert istio-token app-secrets ceph-storage-creds]: timed out waiting for the condition ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-xs9t5 cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-taskrunner-787df76c74-98h5l cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
Known issues
I0622 01:31:28.917107 28815 request.go:601] Waited for 1.017599292s due to client-side throttling, not priority and fairness, request: GET:https://ci-asaks4011056-fwwpyxm7.hcp.westeurope.azmk8s.io:443/apis/networking.istio.io/v1alpha3
check
, test
, and diagnose
) support additional filtering and output format.
Filtering
Filters |
Description |
Usages |
Comma-separated list of the services to include in the validation |
This command runs the diagnose only against Istio and Insights. |
Comma-separated list of the services to exclude from the validation |
This command runs the test in the entire cluster, except Istio and Insights. |
Output format
json
, yaml
, text
, and junit
. You can pass these values to any of the command via the --output
flag. These output formats are handy when you want to leverage these tools to build your own troubleshooting framework on
top of them.
Example usages
Usage |
Example Output |
INFO logs in green show that the required checks passed. However, you should still properly check the disk/memory usage to avoid hidden errors.
Even though these messages do not signal a high risk, you might have to rectify them, as they might be affecting some services in certain scenarios.
You must fix the issues described by these messages as they impact some service in the cluster.
If these services are down, it means the node is down. Try restarting the service using systemctl restart <service-name> as this should fix the issue.
/var/lib
as Kubernetes uses it to store its data. If the directory is full, various issues might arise. To prevent these problems,
make sure to increase its size.
For all the nodes, we specify if they are under Disk Pressure or Memory Pressure. If that happens, workloads on these nodes might start showing issues. Check if there are any other processes running on these nodes that are consuming resources and remove them if that is the case.
We use Ceph as S3 Object storage for storing logs and files from different applications. You can view the status of its services. If they are down, you might have to restart them. Make sure to also check if the disk usage by Ceph is full.
443
and 31443
to be open with the hostname that was provided. The report indicates if they are not accessible. Make sure to open the appropriate
ports if pointed here.
The tool checks if the uploaded certificate is valid for the given hostname and if it has not expired. If the certificate does not meet these criteria, errors occur. To prevent this, make sure to check your uploaded certificate and change it if required.
Since some services require GPU to be present on some of the nodes in the cluster, the Automation Suite Diagnostics Tool checks if there is are GPU nodes and prints number of such nodes. If you are expecting GPU nodes to be present and they do not show up here, that means something went wrong in GPU setup.
RabbitMQ and DockerRegistry are two important components that some services use. If any of them is down, you need to investigate the issue and a restart.
ArgoCD is our application lifecycle management (ALM) tool. If any of its services are down, then other applications may become outdated or have other issues. Recovering these services is important, and might need further debugging.
The Automation Suite Diagnostics Tool shows whether ArgoCD applications are missing and degraded.
- If applications are missing, go to the ArgoCD UI and sync it.
- If applications are degraded, additional debugging is needed to investigate the errors thrown by ArgoCD
- Quick validation
- Quick validation
- Health check
- Health test
- Deep validation
- Deep validation
- Additional utilities
- Additional uitilities
- Reading Diagnostics Reports
- INFO Logs
- WARN Messages
- ERROR Messages
- Rke2-server or Rke2-agent Service Down
- Directory Size Mounted at /var/lib
- Rke2 Version
- Disk Pressure or Memory Pressure
- Ceph Services Status
- Ports 443 and 31443
- Certificate Validity
- GPU
- RabbitMQ and DockerRegistry
- ArgoCD Services Down
- Missing or Degraded ArgoCD Applications
