- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Installation packages download links
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Package |
Purpose |
uipathctl |
UiPath.OrganizationMigrationApp |
hydrate-registry.sh |
as-fs.tar.gz |
-O
parameter.
as-installer.zip
is an installation package that contains the main installation and supporting scripts. The package also contains the uipathctl
tool.
as-installer.zip
. If you opt for the online installation profile, as-installer.zip
is automatically downloaded by the interactive installation wizard.
as-installer.zip
file is required during installation, upgrade, cluster restore in the event of disaster, and while adding new node to existing
cluster.
https://download.uipath.com/automation-suite/2023.10.3/installer-2023.10.3.zip
Linux:
To downloadas-installer.zip
on a Linux machine, run the following command from the terminal:wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.3/installer-2023.10.3.zip
wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.3/installer-2023.10.3.zip -
Windows:
on a Windows machine, click here and rename the file toas-installer.zip
https://download.uipath.com/automation-suite/2023.10.2/installer-2023.10.2.zip
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.2/installer-2023.10.2.zip
wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.2/installer-2023.10.2.zip -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/installer-2023.10.1.zip
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.1/installer-2023.10.1.zip
wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.1/installer-2023.10.1.zip -
Windows:
https://download.uipath.com/automation-suite/2023.10.0/installer-2023.10.0.zip
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.0/installer-2023.10.0.zip
wget -O ~/as-installer.zip https://download.uipath.com/automation-suite/2023.10.0/installer-2023.10.0.zip -
Windows:
as.tar.gz
contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product. The bundle is
approximately 30 GiB in size.
as.tar.gz
is ideal for users with strong network connections who wish to download the complete file in one go.
as.tar.gz
. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly
from the container registry hosted in UiPath® servers.
as.tar.gz
is required during installation and upgrade only on server node when using internal Docker registry.
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3.tar.gz
For the checksum file, click here.
Linux:
To downloadas.tar.gz
on a Linux machine, run the following command from the terminal:wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3.tar.gz
wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3.tar.gz -
Windows:
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2.tar.gz
wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2.tar.gz -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1.tar.gz
wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1.tar.gz -
Windows:
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0.tar.gz
wget -O ~/as.tar.gz https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0.tar.gz -
Windows:
as.tar.gz
as.tar.gz
is designed for users with restricted networks, or those who may encounter challenges when downloading larger files.
as.tar.gz
as.tar.gz
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-001
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-002
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-003
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-004
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-005
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-006
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-007
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-008
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-009
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-010
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-011
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-012
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-013
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-014
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-015
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-016
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-017
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-018
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-019
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-020
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-021
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-022
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-023
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-024
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-025
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-026
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-027
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-028
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-029
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-030
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-031
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-032
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-033
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-034
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-035
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-036
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-037
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-038
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-039
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-040
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-041
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-042
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-043
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-044
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-045
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-046
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-047
https://download.uipath.com/automation-suite/2023.10.3/as-2023.10.3-part-048
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-001
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-002
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-003
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-004
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-005
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-006
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-007
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-008
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-009
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-010
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-011
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-012
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-013
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-014
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-015
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-016
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-017
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-018
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-019
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-020
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-021
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-022
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-023
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-024
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-025
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-026
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-027
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-028
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-029
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-030
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-031
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-032
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-033
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-034
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-035
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-036
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-037
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-038
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-039
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-040
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-041
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-042
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-043
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-044
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-045
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-046
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-047
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-048
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-049
https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-050
Linux:
To download each split file on a Linux machine, you can use thewget
command. To download the first part, run the following command:wget https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-001
wget https://download.uipath.com/automation-suite/2023.10.2/as-2023.10.2-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gz
file:cat as-2023.10.2-part-* > as.tar.gz
cat as-2023.10.2-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by clicking the corresponding download links provided above. Each link represents a part of the fullAfter downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gz
file.as.tar.gz
file:copy /b as-2023.10.2-part-* as.tar.gz
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-001
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-002
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-003
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-004
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-005
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-006
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-007
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-008
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-009
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-010
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-011
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-012
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-013
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-014
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-015
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-016
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-017
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-018
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-019
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-020
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-021
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-022
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-023
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-024
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-025
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-026
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-027
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-028
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-029
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-030
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-031
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-032
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-033
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-034
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-035
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-036
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-037
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-038
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-039
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-040
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-041
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-042
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-043
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-044
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-045
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-046
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-047
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-048
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-049
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-050
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-051
https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-052
Linux:
command. Below is the command to download the first part:wget https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-001
wget https://download.uipath.com/automation-suite/2023.10.1/as-2023.10.1-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
file:cat as-2023.10.1-part-* > as.tar.gz
cat as-2023.10.1-part-* > as.tar.gz -
Windows:
file.as.tar.gz
file:copy /b as-2023.10.1-part-* as.tar.gz
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-001
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-002
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-003
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-004
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-005
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-006
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-007
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-008
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-009
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-010
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-011
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-012
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-013
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-014
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-015
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-016
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-017
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-018
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-019
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-020
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-021
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-022
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-023
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-024
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-025
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-026
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-027
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-028
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-029
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-030
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-031
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-032
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-033
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-034
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-035
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-036
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-037
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-038
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-039
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-040
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-041
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-042
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-043
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-044
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-045
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-046
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-047
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-048
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-049
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-050
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-051
https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-052
Linux:
command. Below is the command to download the first part:wget https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-001
wget https://download.uipath.com/automation-suite/2023.10.0/as-2023.10.0-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
file:cat as-2023.10.0-part-* > as.tar.gz
cat as-2023.10.0-part-* > as.tar.gz -
Windows:
file.as.tar.gz
file:copy /b as-2023.10.0-part-* as.tar.gz
du-ondemand.tar.gz
contains base images to install Document Understanding packages.
du-ondemand.tar.gz
. If you choose the online installation profile, Automation Suite pulls all the Document Understanding base images directly
du-ondemand.tar.gz
is required only when Document Understanding is installed.
For download instructions, see ML Packages Offline Installation.
du-ondemand.tar.gz
cv-ondemand.tar.gz
contains Computer Vision models and packages.
cv-ondemand.tar.gz
. If you choose the online installation profile, Automation Suite will pull all the Computer Vision models directly from the
cv-ondemand.tar.gz
is required only when you want to use Computer Vision models.
https://download.uipath.com/automation-suite/2023.10.3/cv2310-2023.10.3.tar.gz
Linux:
To downloadcv-ondemand.tar.gz
on a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.3/cv2310-2023.10.3.tar.gz
wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.3/cv2310-2023.10.3.tar.gz -
Windows:
on a Windows machine, click here and rename the file tocv-ondemand.tar.gz
https://download.uipath.com/automation-suite/2023.10.2/cv2310-2023.10.2.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.2/cv2310-2023.10.2.tar.gz
wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.2/cv2310-2023.10.2.tar.gz -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/cv2310-2023.10.1.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.1/cv2310-2023.10.1.tar.gz
wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.1/cv2310-2023.10.1.tar.gz -
Windows:
cv-ondemand.tar.gz
bundle contains Computer Vision 2023.4.3.
https://download.uipath.com/automation-suite/2023.10.0/cv-2023.10.0.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.0/cv-2023.10.0.tar.gz
wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2023.10.0/cv-2023.10.0.tar.gz -
Windows:
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
Linux
To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command on the terminal:
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.4-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.4-linux.zip -
Windows
To download UiPath.OrganizationMigrationApp on a Windows machine, click here.
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.2-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.2-linux.zip -
Windows
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.1-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.1-linux.zip -
Windows
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.0-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.0-linux.zip -
Windows
uipathtools
is a CLI tool that contains a subset of uipathctl
capabilities specific to health commands. The tool is backwards compatible and works with any of the supported Automation
Suite versions. We recommend using uipathtools
as the first step if you face any issue.
uipathtools
, run one of the following commands, depending on your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-darwin-amd64.tar.gz
uipathtools
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-darwin-amd64.tar.gz
uipathtools
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-darwin-amd64.tar.gz
uipathtools
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-darwin-amd64.tar.gz
configureUiPathDisks.sh
to partition the disk before installation.
The latest version of the script works with all 2023.10.x versions of Automation Suite.
https://download.uipath.com/automation-suite/2023.10.3/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.sh
on a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.3/configureUiPathDisks.sh
wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.3/configureUiPathDisks.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.2/configureUiPathDisks.sh
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.2/configureUiPathDisks.sh
wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.2/configureUiPathDisks.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/configureUiPathDisks.sh
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.1/configureUiPathDisks.sh
wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.1/configureUiPathDisks.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.0/configureUiPathDisks.sh
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.0/configureUiPathDisks.sh
wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2023.10.0/configureUiPathDisks.sh -
Windows:
supportability-tools
works with all Automation Suite versions.
https://download.uipath.com/automation-suite/2023.10.3/supportability-tools-2023.10.3.zip
Linux:
To downloadsupportability-tools
on a Linux machine, run the following command from the terminal:wget -O ~/supportability-tools.zip https://download.uipath.com/automation-suite/2023.10.3/supportability-tools-2023.10.3.zip
wget -O ~/supportability-tools.zip https://download.uipath.com/automation-suite/2023.10.3/supportability-tools-2023.10.3.zip -
Windows:
on a Windows machine, click here and rename the file tosupportability-tools
objectstore-migration.sh
helps you migrate Objectstore data in online and offline installations.
https://download.uipath.com/automation-suite/objectstore-migration.sh
Linux:
To downloadobjectstore-migration.sh
on a Linux machine, run the following command from the terminal:wget -O ~/objectstore-migration.sh https://download.uipath.com/automation-suite/objectstore-migration.sh
wget -O ~/objectstore-migration.sh https://download.uipath.com/automation-suite/objectstore-migration.sh -
Windows:
Linux:
Windows:
Linux:
Windows:
Linux:
Windows:
automation-suite-util.tar.gz
helps you migrate Objectstore data in offline installations.
https://download.uipath.com/automation-suite/automation-suite-util.tar.gz
Linux:
To downloadautomation-suite-util.tar.gz
on a Linux machine, run the following command from the terminal:wget -O ~/automation-suite-util.tar.gz https://download.uipath.com/automation-suite/automation-suite-util.tar.gz
wget -O ~/automation-suite-util.tar.gz https://download.uipath.com/automation-suite/automation-suite-util.tar.gz -
Windows:
Linux:
Windows:
Linux:
Windows:
Linux:
Windows:
mirror-registry.sh
is required to configure an external Docker registry.
https://download.uipath.com/automation-suite/2023.10.3/mirror-registry.sh
Linux:
To downloadmirror-registry.sh
on a Linux machine, run the following command from the terminal:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.3/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.3/mirror-registry.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.2/mirror-registry.sh
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2/mirror-registry.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/mirror-registry.sh
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.1/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.1/mirror-registry.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.0/mirror-registry.sh
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.0/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.0/mirror-registry.sh -
Windows:
hydrate-registry.sh
is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
https://download.uipath.com/automation-suite/2023.10.3/hydrate-registry.sh
Linux:
To download
on a Linux machine, run the following command from the terminal:hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.3/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.3/hydrate-registry.sh -
Windows:
To downloadhydrate-registry.sh
https://download.uipath.com/automation-suite/2023.10.2/hydrate-registry.sh
Linux:
To download
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2/hydrate-registry.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/hydrate-registry.sh
Linux:
To download
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.1/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.1/hydrate-registry.sh -
Windows:
https://download.uipath.com/automation-suite/2023.10.0/hydrate-registry.sh
Linux:
To download
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.0/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.0/hydrate-registry.sh -
Windows:
as-images.txt
contains the name and version of the container images that are required to be pulled and uploaded into the external Docker
registry.
https://download.uipath.com/automation-suite/2023.10.3/embedded-images.txt
To download
Linux:
embedded-images.txt
on a Linux machine, run the following command from the terminal:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.3/embedded-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.3/embedded-images.txt -
To download
Windows:
embedded-images.txt
on a Windows machine, click hereand rename the file toas-images.txt
https://download.uipath.com/automation-suite/2023.10.2/embedded-images.txt
To download
Linux:
embedded-images.txt
on a Linux machine, run the following command from the terminal:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.2/embedded-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.2/embedded-images.txt -
To download
Windows:
embedded-images.txt
https://download.uipath.com/automation-suite/2023.10.1/embedded-images.txt
To download
Linux:
embedded-images.txt
on a Linux machine, run the following command from the terminal:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.1/embedded-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.1/embedded-images.txt -
To download
Windows:
embedded-images.txt
https://download.uipath.com/automation-suite/2023.10.0/embedded-images.txt
To download
Linux:
embedded-images.txt
on a Linux machine, run the following command from the terminal:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.0/embedded-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.0/embedded-images.txt -
To download
Windows:
embedded-images.txt
as-helm-charts.txt
contain the details for the UiPath® application helm chart that must be pulled and uploaded to external Docker registry hosted
on your environment.
https://download.uipath.com/automation-suite/2023.10.3/embedded-helm-charts.txt
To download
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.3/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.3/embedded-helm-charts.txt -
To download
Windows:
on a Windows machine, click hereand rename the file toas-helm-charts.txt
https://download.uipath.com/automation-suite/2023.10.2/embedded-helm-charts.txt
To download
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2/embedded-helm-charts.txt -
To download
Windows:
https://download.uipath.com/automation-suite/2023.10.1/embedded-helm-charts.txt
To download
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.1/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.1/embedded-helm-charts.txt -
To download
Windows:
https://download.uipath.com/automation-suite/2023.10.0/embedded-helm-charts.txt
To download
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.0/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.0/embedded-helm-charts.txt -
To download
Windows:
as-fs.tar.gz
contains the Helm charts and images to deploy the fabric and service components in offline mode.
https://download.uipath.com/automation-suite/2023.10.3/as-fs-2023.10.3.tar.gz
Linux:
To downloadas-fs.tar.gz
on a Linux machine, run the following command from the terminal:wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.3/as-fs-2023.10.3.tar.gz
wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.3/as-fs-2023.10.3.tar.gz -
Windows:
https://download.uipath.com/automation-suite/2023.10.2/as-fs-2023.10.2.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.2/as-fs-2023.10.2.tar.gz
wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.2/as-fs-2023.10.2.tar.gz -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/as-fs-2023.10.1.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.1/as-fs-2023.10.1.tar.gz
wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.1/as-fs-2023.10.1.tar.gz -
Windows:
https://download.uipath.com/automation-suite/2023.10.0/as-fs-2023.10.0.tar.gz
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.0/as-fs-2023.10.0.tar.gz
wget -O ~/as-fs.tar.gz https://download.uipath.com/automation-suite/2023.10.0/as-fs-2023.10.0.tar.gz -
Windows:
Needed to perform prerequisite checks and installation steps.
https://download.uipath.com/automation-suite/2023.10.3/versions.json
Linux:
To downloadversions.json
on a Linux machine, run the following command from the terminal:wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.3/versions.json
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.3/versions.json -
Windows:
https://download.uipath.com/automation-suite/2023.10.2/versions.json
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.2/versions.json
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.2/versions.json -
Windows:
https://download.uipath.com/automation-suite/2023.10.1/versions.json
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.1/versions.json
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.1/versions.json -
Windows:
https://download.uipath.com/automation-suite/2023.10.0/versions.json
Linux:
on a Linux machine, run the following command from the terminal:wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.0/versions.json
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.0/versions.json -
Windows:
- as-installer.zip
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- Full as.tar.gz
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- Split as.tar.gz
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- du-ondemand.tar.gz
- cv-ondemand.tar.gz
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- UiPath.OrganizationMigrationApp
- 2023.10.4
- 2023.10.2
- 2023.10.1
- 2023.10.0
- uipathtools
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- configureUiPathDisks.sh
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- supportability-tools
- objectstore-migration.sh
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- automation-suite-util.tar.gz
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- mirror-registry.sh
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- hydrate-registry.sh
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- as-images.txt
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- as-helm-charts.txt
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- as-fs.tar.gz
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
- versions.json
- 2023.10.3
- 2023.10.2
- 2023.10.1
- 2023.10.0
