- 概述
- 要求
- 安装
- 安装后
- 集群管理
- 监控和警示
- 迁移和升级
- 特定于产品的配置
- 最佳实践和维护
- 故障排除
A) 完全安装迁移
This is one of two ways in which you can migrate your standalone Orchestrator to Automation Suite. In addition to Orchestrator, this method helps you migrate other products and services. For more information, see Migration options.
The full migration option ensures high fidelity data transfer between the standalone product databases and the automatically created Automation Suite databases. If you do not want to use the default Automation Suite databases, you can opt for your own migrated databases provided that you update their connection strings.
我们已将迁移任务组织为清单,您可以在完成任务时选中每个复选框以跟踪进度。 但是,如果刷新页面,刻度将丢失。
You can also download the migration checklist as an Excel spreadsheet.
要从独立部署迁移到 Automation Suite,请执行以下步骤:
| 阶段 | 描述 | 说明 |
1 |
升级独立部署 |
2 |
部署 Automation Suite |
3 |
请遵循迁移前的步骤 |
4 |
备份数据库 |
5 |
还原数据库 |
6 |
更新数据库连接字符串 |
Update the database connection strings for the restored databases via ArgoCD. Details... |
7 |
请遵循迁移后的步骤 |
