Automation Suite 安装指南
- 概述
- 要求
- 安装
- 安装后
- 集群管理
- 监控和警示
- 迁移和升级
- 特定于产品的配置
- 最佳实践和维护
- 故障排除
请注意,此内容已使用机器翻译进行了部分本地化。
新发布内容的本地化可能需要 1-2 周的时间才能完成。
存储回收补丁
描述
为确保高性能并防止中断,我们通过回收未使用的存储来优化 Automation Suite 的集群存储。但是,系统偶尔可能会回收一些经常使用的存储,从而影响多节点集群的服务,并可能导致单节点集群的数据丢失。
以下版本受此问题的影响:
- 2021.10.3 至 2021.10.10
- 2022.4.8 及更早版本
- 2022.10.7 及更早版本
- 2023.4.2 及更早版本
解决方案
要确保 Automation Suite 不会回收节点上经常使用的存储,请运行以下脚本:
#!/bin/bash
echo ""
echo "Starting Storage Reclamation Patch"
echo ""
echo "Checking that this is a server node"
if [ $(sudo systemctl is-enabled rke2-server) ]; then
echo " This is a server node"
echo ""
else
echo " FATAL: This is not a server node"
echo " This script should only be run on a server node"
echo "Exiting script"
echo ""
exit 1
fi
echo "Generating patch.yaml file at: /tmp/patch.yaml"
if [ -f /tmp/patch.yaml ]; then
echo " FATAL: Patch file: /tmp/patch.yaml file already exists"
echo " Remove existing /tmp/patch.yaml file and re-run script"
echo " Command to remove file: sudo rm -rf /tmp/patch.yaml"
echo ""
exit 1
fi
sudo cat <<'EOF' > /tmp/patch.yaml
spec:
template:
spec:
containers:
- name: longhorn-replica-folder-cleanup
args:
- /host
- /bin/bash
- -ec
while true;
do
set -o pipefail
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:$INSTALLER_PATH
which kubectl >> /dev/null || {
echo "kubectl not found"
exit 1
which jq >> /dev/null || {
echo "jq not found"
exit 1
directories=$(find ${LONGHORN_DISK_PATH}/replicas/ -maxdepth 1 -mindepth 1 -type d)
for dir in $directories;
do
basename=$(basename "$dir")
volume_name=${basename%-*}
replica_name=$(kubectl -n longhorn-system get replicas.longhorn.io -o json | jq --arg dir "$basename" '.items[] | select(.spec.dataDirectoryName==$dir) | .metadata.name')
if kubectl -n longhorn-system get volumes.longhorn.io "$volume_name" &>/dev/null;
then
if [[ -z ${replica_name} ]];
then
robust_status=$(kubectl -n longhorn-system get volumes.longhorn.io "$volume_name" -o jsonpath='{.status.robustness}')
if [[ "${robust_status}" == "healthy" || "${robust_status}" == "degraded" ]];
then
echo "Replica not found but Volume found with a valid status (robust status ${robust_status}). Data directory $dir can be deleted"
rm -rf $dir
else
echo "Replica not found but Volume found with robust status ${robust_status}. Need to check if there is still a valid replica before deleting data directory $dir so that the directory is not required for recovery"
fi
else
echo "Volume found and there is a replica using the data directory $dir"
fi
else
if kubectl -n longhorn-system get volumes.longhorn.io "$volume_name" 2>&1 | grep "NotFound";
then
echo "Volume object not found. Data directory $dir can be deleted."
rm -rf $dir
else
echo "Could not fetch volume for $dir"
fi
fi
done
sleep 600
done
EOF
# Checker to see if patch.yaml file was created
echo " /tmp/patch.yaml file created"
echo ""
else
echo " FATAL: /tmp/patch.yaml file not created"
echo " Previous command did not run successfully. Try running: sudo touch /tmp/patch.yaml to see why the command failed to generate the file /tmp/patch.yaml"
echo " If help is needed, please contact UiPath Support"
echo ""
exit 1
fi
echo "Applying patch.yaml file"
echo ' Executing the command: sudo /var/lib/rancher/rke2/bin/kubectl --kubeconfig /etc/rancher/rke2/rke2.yaml -n kube-system patch daemonset longhorn-replica-folder-cleanup --patch "$(cat /tmp/patch.yaml)"'
sudo /var/lib/rancher/rke2/bin/kubectl --kubeconfig /etc/rancher/rke2/rke2.yaml -n kube-system patch daemonset longhorn-replica-folder-cleanup --patch "$(cat /tmp/patch.yaml)" 1>/dev/null
exit_code=$?
echo ""
echo "Checking that the patch was applied"
if [ $exit_code -eq 0 ]; then
echo " Patch was applied successfully"
echo ""
else
echo " FATAL: Patch was not applied successfully"
echo " Previous command did not run successfully. Check previous errors and Contact UiPath Support for help."
echo " Before re-running script please run this command: sudo rm -f /tmp/patch.yaml"
echo ""
exit 1
fi
echo "Removing /tmp/patch.yaml file"
echo ""
echo "System is patched. Make sure to run this tool in all environments on any master node"
echo ""
#!/bin/bash
echo ""
echo ""
echo ""
else
echo ""
exit 1
fi
echo ""
exit 1
fi
spec:
template:
spec:
containers:
args:
- /host
- /bin/bash
- -ec
while true;
do
set -o pipefail
exit 1
echo "jq not found"
exit 1
do
then
then
then
rm -rf $dir
else
fi
else
fi
else
then
rm -rf $dir
else
fi
fi
done
sleep 600
done
EOF
echo ""
else
echo ""
exit 1
fi
exit_code=$?
echo ""
echo ""
else
echo ""
exit 1
fi
echo ""
echo ""
运行脚本:
要运行脚本,请执行以下步骤:
将脚本复制到其中一个 Automation Suite 服务器节点,并将其命名为
storageReclamationPatch.sh。 -
更改权限以使脚本可执行:
chmod 755 storageReclamationPatch.shchmod 755 storageReclamationPatch.sh -
执行脚本:
确保已启用脚本编写功能,以便可以在日志文件中捕获脚本的执行和输出。如果遇到任何问题,这将有助于我们的支持团队诊断问题。
要启动脚本编写程序并执行补丁脚本,请运行以下命令:
script storageReclamationPatch.log ./storageReclamationPatch.sh
使用
exit命令退出脚本并生成storageReclamationPatch.log日志文件。如果您在此阶段遇到任何问题,请与我们的支持团队分享。
运行脚本的示例:
[admin_1@autosuite storageReclamationPatch]$ script storageReclamationPatch.log
Script started, file is storageReclamationPatch.log
[admin_1@autosuite storageReclamationPatch]$ ./storageReclamationPatch.sh
//Script executes, maybe some debugging is done
[admin_1@autosuite storageReclamationPatch]$ exit
exit
Script done, file is storageReclamationPatch.log
exit
如果执行成功,脚本将显示以下消息:
Checking that the patch was applied Patch was applied successfully
备注:
该脚本只需在每个环境的一个服务器节点上执行。如果脚本失败或遇到无法解决的问题,请与支持团队共享 storageReclamationPatch.log 文件。
