- 概述
- 要求
- 安装
- 安装后
- 集群管理
- 监控和警示
- 迁移和升级
- 特定于产品的配置
- 最佳实践和维护
- 故障排除
AI Center 注意事项
除了作为完整平台要求一部分的核心服务要求之外,AI Center 还需要其他资源,具体取决于您要运行或训练的模型。有关所需 GPU 硬件版本和兼容的 NVIDIA 驱动程序的更多详细信息,请参阅兼容性矩阵。
The following table describes the additional resources AI Center needs. In this table, Data Disk is needed on all server nodes. This is not needed on agent nodes.
| 使用 | CPU | RAM (GiB) | GPU | 磁盘 (GiB) |
用于服务的最小值(ML 技能,一个副本) |
0.6 |
2 |
0 |
用于训练的最小值(管道) |
1 |
4 |
0 |
DU 模型服务(ML 技能,一个副本) |
1 |
4 |
0 |
DU 模型训练 |
2 |
24 |
强烈推荐 |
The following table describes the required resources for small and average AI Center implementations. Note that these numbers are general guidance. In this table, Data Disk is needed on all server nodes. This is not needed on agent nodes.
小型实现:
4 |
32 |
0 |
平均实现:
8 |
52 |
强烈推荐 |
1 (3 skills +1 pipeline) * 20 GiB on the rancher partition = 80 GiB on the rancher partition
2 1 个管道 * 105GB = 105 数据磁盘
3 (5 skills + 2 pipeline + 1 DU pipeline) * 20 GiB on the rancher partition = 160 GiB on the rancher partition
4(2 个管道 + 1 个 DU 管道)* 105GB = 315 数据磁盘
