Studio
2020.10
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- Variables
- Arguments
- Imported Namespaces
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The ScaleCoordinates Migration Tool
- The WebDriver Protocol
- StudioPro
- Extensions
- Troubleshooting
Example of Using OCR and Image Automation
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&q=100)
OUT OF SUPPORT
Studio User Guide
Last updated Dec 20, 2023
Since OCR and Image automation usually go hand in hand due to the difficulty of automating in virtual environments, we created an automation that retrieves an employee’s email and the invoice number from a scanned invoice. Afterwards, it inputs the information into a dummy expense app (ExpenseIt) on a virtual machine, and compares the total from the invoice with the one in the app:
Since this automation involves connecting to a virtual machine, uploading the original project is redundant, as it would not work on another machine. We encourage you to build your own project by following the above steps.
