- Notas relacionadas
- Antes de empezar
- Gestionar el acceso
- Primeros pasos
- Integraciones
- Showing or hiding the menu
- Información del contexto
- Exportar
- Filtros
- Etiquetas
- Fechas límite
- Comparar
- Comprobación de conformidad
- Simulación de procesos
- Análisis de causa raíz
- Iniciar un proyecto de Task Mining desde Process Mining
- Ver datos del proceso
- Creación de aplicaciones
- Cargar datos
- Transforming data
- Tips for writing SQL
- Configuración de etiquetas
- Configuración de actividad: definición del orden de actividad
- Modelos de datos
- Añadir y editar procesos
- Personalizar apps de proceso
- Publicar aplicaciones de proceso
- Plantillas de la aplicación
- Efficiency - Order process velocity
- Eficiencia - Rendimiento del proveedor
- Cumplimiento - Compra de Maverick
- KPI
- Purchase to Pay - SAP input fields
- Notificaciones
- Recursos adicionales
Process Mining
The Order process velocity dashboard enables you to analyze and monitor the speed and efficiency of purchase order execution across the end-to-end Purchase to Pay process.
Chart | Descripción |
PR to GR milestones |
A bar chart that shows the time intervals and milestones from the creation of the Purchase requisition (PR) to the completion of a Goods receipt (GR). The PR to GR milestones chart allows you to track the flow, timing, and efficiency of the end to end process from purchase requisition to goods delivery. |
Revision PO items analysis | A bar chart that provides information on the number and of changes made to purchase order (PO) items within the end-to-end process. |
Revision events analysis |
A bar chart that provides information on the number, type, and distribution of revision (change) events that occurred across PO items in the end-to-end process. The Revision event analysis chart allows you to analyze process instability and rework trends that reduce speed and impact the number of first time right PO items. |
Tendencia | The graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order creation date. |
