Automation Suite
Step 1: Creating a tenant for each Automation Suite organization - Automation Suite 2023.10
Banner background image
logo
Automation Suite on Linux Installation Guide
Last updated Feb 13, 2024
For each tenant from the standalone deployment, create an organization-tenant pair in the Automation Suite environment.
For example, if in standalone Orchestrator you have a tenant named Tenant1, then in Automation Suite you must create an organization named Tenant1 and a tenant within that organization also named Tenant1. Once you create the tenant, make sure the Orchestrator service is enabled for that tenant.
Note:
A DefaultTenant tenant is automatically created for each organization. You must add another tenant named exactly like your organization. In the previous example, when creating an organization Tenant1, you end up also having a tenant named DefaultTenant in that organization. The final step for you is to add another tenant called Tenant1 to that organization. You can then move on to creating the next organization-tenant pair.
Support and Services icon
UiPath Academy icon
UiPath Forum icon
