- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&q=100)
For detailed instructions on how to back up and restore Automation Suite, see Backing up and restoring the cluster.
You must back up only the primary cluster and external storage (SQL and Objectstore).
It is not mandatory to take a backup of the secondary cluster. Instead, you can choose to take a backup of the secondary. However, you can still use the primary cluster to set up the secondary cluster.
If the primary cluster goes down, you must use the backup to restore it.
If you applied a new configuration on the secondary cluster while the primary cluster is down, then at the time of the restore, you can reuse the
cluster_config.json
file of the secondary cluster and update the critical parameter, which is very specific to the primary cluster, and then you can restore the cluster.
If the secondary cluster’s backup is unavailable, you can restore it from the primary cluster by taking the following steps:
Generate the
cluster_config.json
from the primary cluster. -
Update the
cluster_config.json
with the specific value of the secondary cluster. -
Install the secondary cluster.
If the backup for the secondary cluster is available, you can restore the secondary cluster from the backup.
