- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Skipping host library creation
- Troubleshooting
SQL database
Only Microsoft ODBC Driver 17 is supported.
Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
You must bring an external SQL server to install Automation Suite and UiPath® products. Microsoft SQL Server 2017, 2019, and 2022 Standard and Enterprise editions are supported.
Currently, Orchestrator and AI Center require SQL Server version 2019 and higher to function optimally.
SQL Server 2016 and 2017 are not supported in the Automation Suite versions from 2024.10.0 to 2024.10.2. All SQL versions are supported starting with Automation Suite versions 2024.10.3 or higher for all applications except Insights.
Additional Microsoft SQL platforms, such as Azure SQL Database, Azure SQL Managed Instance, or Amazon Relational Database Service, are also supported as long as the Microsoft SQL Server database engine meets the requirements. For details, see Compatibility matrix.
If Process Mining is enabled and you want to use the latest version of Airflow, PostgreSQL is required for the AutomationSuite_Airflow database. (Version 2024.10.3 or higher.)
Refer to SQL requirements for Process Mining for more information.
Make sure that the SQL server can be accessed from the cluster nodes.
Individual product support varies.
For each product you plan to deploy, you must:
- check the supported version of SQL Server as required by the product;
- meet the SQL Server configuration requirements, including SQL Server User permissions, as the product requires.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
- 8 (v-)CPU
- 32 GB RAM
- 256 GB SSD
The minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements for reliable operation. For details, see Capacity planning.
Each UiPath® product requires its own SQL database.
Database creation workflow
The interactive installer automatically creates databases using the following workflow:
The interactive installer script checks the value of the
sql.create_dbparameter in theinput.jsonfile.- If the
sql.create_dbparameter is set totrue, the installer automatically generates all the databases on your behalf. In this case, the installer uses the default database names and default templates, and ignores any custom database names you provided.
For details, see Automatically create the necessary databases.
- If
sql.create_dbis set tofalse, you must bring your own databases. In this case, you must manually set up your databases. Note that you can use custom database names, provided that you follow the provided naming conventions. This step is critical because we use the database name in conjunction with the connection template to form the database connection string. If you do not follow the recommended naming convention, you must provide the SQL connection strings yourself.
For details, see Bring your own databases.
- If the
The interactive installer generates the connection strings as follows:
- If you did not define a connection string for your service, the installer uses the connection template to generate all database connection strings.
- If you defined a connection string for your service, the installer uses the provided connection string for your database.
If you want the installer to create the databases, fill in the following fields of the input.json file:
| Parameter | Description |
sql.create_db | Set to true to allow the installer to create the databases. Note that the installer uses the default database names and default templates, and ignores any custom database names you provided. |
sql.server_url | FQDN of the SQL server, where you want the installer to configure database. |
sql.port | Port number on which a database instance should be hosted in the SQL server. |
sql.username | Username / user ID to connect to the SQL server. |
sql.password | Password of the username provided earlier to connect to the SQL server. |
- Ensure the user has the
dbcreatorrole. This grants them permission to create the database in SQL Server. Otherwise, the installation fails. - Automatically creating the necessary databases does not work in combination with directory authentication. If you use directory authentication, you must bring your own databases.
- ODBC connection does not support usernames that contain special characters. For database usernames for AI Center, Document Understanding, and Apps, use only uppercase and lowercase letters.
For Process Mining on Automation Suite 2024.10.3 or higher, using PostgreSQL for the Airflow database is the recommended option. If you choose to use a PostgreSQL database, you need to manually create the PostgreSQL database for AutomationSuite_Airflow before installing or upgrading to Automation Suite 2024.10.3 or higher. The PostgreSQL database for Airflow will not be created automatically by the installer.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
If you bring your own database, you must provide the SQL connection strings for every database. Automation Suite supports the following SQL connection string formats:
For Document Understanding, make sure that you are using the same database, unless otherwise explicitly stated. Specific connection strings are assigned to various services and jobs that connect to the same database.
| Parameter | Description | Products |
sql_connection_string_template | Full ADO.NET connection string where Catalog name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. | Platform Orchestrator Automation Suite Robots Test Manager Automation Hub Automation Ops Insights Data Service Process Mining Document Understanding |
sql_connection_string_template_jdbc | Full JDBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. | AI Center |
sql_connection_string_template_odbc | Full ODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. | Document Understanding Apps |
sql_connection_string_template_sqlalchemy_pyodbc | Full SQL alchemy PYODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. | Document Understanding Process Mining |
postgresql_connection_string_template_sqlalchemy_pyodbc | Full SQL alchemy PSYCOPG2 connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. | Process Mining (2024.10.3 or newer) |
Make sure the SQL account specified in the connection strings is granted the db_owner role for all Automation Suite databases. If security restrictions do not allow the use of db_owner, then the SQL account should have the following roles and permissions on all databases:
db_securityadmindb_ddladmindb_datawriterdb_datareaderEXECUTEpermission on dbo, dt, authz, and msgbus schema
Insights requires the db_owner role to be assigned for a successful installation.
By default, TrustServerCertificate is set to False, and you must provide an additional CA certificate for the SQL Server. This is required if the SQL Server certificate is self-signed or signed by an internal CA. If you do not provide the SQL Server certificate in this scenario, the prerequisite check will fail.
sql_connection_string_template example
Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
sql_connection_string_template_jdbc example
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
sql_connection_string_template_odbc example
SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"
sql_connection_string_template_sqlalchemy_pyodbc example
mssql+pyodbc://testuser%40sfdev3082457-sql.database.windows.net:_-%29X07_%5E3-%28%3B%25e-T@sfdev3082457-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
postgresql_connection_string_template_sqlalchemy_pyodbc example (Process Mining)
postgresql+psycopg2://<user>:<password>@<host>:<port>/DB_NAME_PLACEHOLDER
sql_connection_string_template and postgresql_connection_string_template_sqlalchemy_pyodbc example (Process Mining)
"sql_connection_string_template": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='07<l[xj-=~:z`Ds&nl';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"postgresql_connection_string_template_sqlalchemy_pyodbc ": "postgresql+psycopg2://<user>:<password>@sfdev4515230-postgresql.database.windows.net:5432/DB_NAME_PLACEHOLDER"
sql_connection_string_template and sql_connection_string_template_sqlalchemy_pyodbc example (Process Mining)
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
Default and optional DB names for Automation Suite services
"orchestrator": "AutomationSuite_Orchestrator",
"orchestrator_ta": "AutomationSuite_Orchestrator",
"asrobots": "AutomationSuite_Orchestrator",
"orchestrator_upd": "AutomationSuite_Platform",
"platform": "AutomationSuite_Platform",
"test_manager": "AutomationSuite_Test_Manager",
"automation_ops": "AutomationSuite_Platform",
"automation_hub": "AutomationSuite_Automation_Hub",
"insights": "AutomationSuite_Insights",
"dataservice": "AutomationSuite_DataService",
"aicenter": "AutomationSuite_AICenter",
"documentunderstanding": "AutomationSuite_DU_Datamanager",
"processmining_airflow": "AutomationSuite_Airflow",
"processmining_metadata": "AutomationSuite_ProcessMining_Metadata",
"processmining_warehouse": "AutomationSuite_ProcessMining_Warehouse",
"apps": "AutomationSuite_Apps",
If you want to override the connection string for any of the mentioned services, set the sql_connection_str for that specific service.
You still have to manually create these databases before running the installer.
Overriding the default connection string for Orchestrator and the platform
"orchestrator": {
"sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomOrchDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"platform": {
"sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomIDDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"orchestrator": {
"platform": {
To override the database connection strings for other products, set the sql_connection_str in the corresponding product blocks. The connection string should have a format supported by the respective product.
Example for setting database connection string for AI Center
aicenter.sql_connection_str | AI Center JDBC connection string |
Make sure the JDBC connection string has the format in the following sample:
"aicenter": {
"enabled": true,
"sql_connection_str": "jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net;database=aicenter;user=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;password=TFgID_9GsE7_P@srCQp0WemXX_euHQZJ"
"aicenter": {
"enabled": true,
Sample Document Understanding connection string
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "Server=SERVER_PLACEHOLDER;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=USER_PLACEHOLDER;Password='PASSWORD_PLACEHOLDER';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"datamanager": {
"sql_connection_str": "SERVER=SERVER_PLACEHOLDER;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=USER_PLACEHOLDER;PWD={PASSWORD_PLACEHOLDER};;Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=customer-sql.database.windows.net",
"pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sql.database.windows.net:Z%3Aw%21%zE%3Cb4@sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
"enabled": true,
"datamanager": {
The data manager SQL connection string is optional only if you want to overwrite the default with your own.
Sample Process Mining connection string (PostgreSQL)
"processmining": {
"enabled": true,
"app_security_mode": "system_managed",
"airflow": {
"metadata_db_connection_str": "postgresql+psycopg2://testadmin:<password>@sfdev8454496-postgresql.postgres.database.azure.com:5432/AutomationSuite_Airflow"
"warehouse": {
"sql_connection_str": "Server=tcp:kerberossql.autosuitead.local,1433;Initial Catalog=AutomationSuite_Warehouse;Persist Security Info=False;User Id=testadmin;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin:<password>@kerberossql.autosuitead.local:1433/AutomationSuite_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
"master_sql_connection_str": "Server=tcp:kerberossql.autosuitead.local,1433;Initial Catalog=master;Persist Security Info=False;User Id=testadmin;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='password';Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
"enabled": true,
"airflow": {
"warehouse": {
Sample Process Mining connection string (SQL Server)
"processmining": {
"enabled": true,
"warehouse": {
"sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='password';Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:<password>:@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
"master_sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:<password>@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
"processmining": {
"enabled": true,
"warehouse": {
When using Kerberos authentication, utilize the Integrated Security and Trusted_Connection parameters. By setting Integrated Security to true and setting Trusted_Connection to yes, the credentials of the currently logged in user are used for the connection. In this case, you do not need to specify a separate username and password.
Note that the names for template PYODBC connection string postgresql_connection_string_template_sqlalchemy_pyodbc (for PostgreSQL) respectively sql_connection_string_template_sqlalchemy_pyodbc (for MS SQL Server) and the PYODBC connection string sqlalchemy_pyodbc_sql_connection_str used when you bring your own database are different. Also connection string names are different for the template SQL sql_connection_string_template and sql_connection_str used when you bring your own database.
If you bring your own database and you configured this using the sql_connection_str and sqlalchemy_pyodbc_sql_connection_str connection strings in the processmining section of the input.jsonfile, the template connection strings sql_connection_string_template and postgresql_connection_string_template_sqlalchemy_pyodbc (for PostgreSQL) respectively sql_connection_string_template_sqlalchemy_pyodbc (for MS SQL Server) are ignored if specified.
Set MultiSubnetFailover=True for sql_connection_str and master_sql_connection_str and MultiSubnetFailover=Yes for sqlalchemy_pyodbc_sql_connection_str connection strings. Note that for pyodbc you use '=Yes' instead of '=True'.
Depending on the app_security_mode setting either a new SQL user is created for every Process Mining app by the system (app_security_mode="system_managed"), or a single SQL user account is created that is used for all process apps (app_security_mode="single_account"). Note that app_security_mode="system_managed" is the default setting, and that this requires advanced permissions for the database user.
- Scenario: setup with Kerberos authentication (PostgreSQL)
"processmining": {
"enabled": true,
"airflow": {
"metadata_db_connection_str": "postgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/automationsuite_airflow"
"warehouse": {
"sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
"master_sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"processmining": {
"enabled": true,
"airflow": {
"warehouse": {
- Scenario: setup with Kerberos authentication (Microsoft SQL Server).
"processmining": {
"enabled": true,
"warehouse": {
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes"
"processmining": {
"enabled": true,
"warehouse": {
- Scenario: Metadata database and data warehouse use separate SQL server (Non-Kerberos authentication).
"processmining": {
"enabled": true,
"warehouse": {
"sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration1.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
"master_sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration2.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
"sql_connection_str": "Server=tcp:uipath-integration2.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
"enabled": true,
"warehouse": {
- Scenario: using custom
app_security_mode.
"processmining": {
"enabled": true,
"warehouse": {
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=YES"
"processmining": {
"enabled": true,
"warehouse": {
SQL collation
Automation Suite supports SQL collation set to SQL_Latin1_General_CP1_CI_AS at both the server and database level. We strongly recommend this particular setup for optimum performance and stability.
While you have the flexibility to use a collation of your choice, be aware that untested configurations can potentially lead to unexpected issues.
We do not recommend using Binary SQL or any collations that are case-sensitive, as they cause known issues while installing Automation Suite.
SQL server ciphers
Only the listed SQL ciphers are supported in Automation Suite:
TLS_AES_256_GCM_SHA384TLS_CHACHA20_POLY1305_SHA256TLS_AES_128_GCM_SHA256TLS_AES_128_CCM_SHA256ECDHE-ECDSA-AES256-GCM-SHA384ECDHE-RSA-AES256-GCM-SHA384ECDHE-ECDSA-CHACHA20-POLY1305ECDHE-RSA-CHACHA20-POLY1305ECDHE-ECDSA-AES256-CCMECDHE-ECDSA-AES128-GCM-SHA256ECDHE-RSA-AES128-GCM-SHA256ECDHE-ECDSA-AES128-CCMECDHE-ECDSA-AES128-SHA256ECDHE-RSA-AES128-SHA256ECDHE-ECDSA-AES256-SHAECDHE-RSA-AES256-SHAECDHE-ECDSA-AES128-SHAECDHE-RSA-AES128-SHAAES256-GCM-SHA384AES256-CCMAES128-GCM-SHA256AES128-CCMAES256-SHA256AES128-SHA256AES256-SHAAES128-SHADHE-RSA-AES256-GCM-SHA384DHE-RSA-CHACHA20-POLY1305DHE-RSA-AES256-CCMDHE-RSA-AES128-GCM-SHA256DHE-RSA-AES128-CCMDHE-RSA-AES256-SHA256DHE-RSA-AES128-SHA256DHE-RSA-AES256-SHADHE-RSA-AES128-SHAPSK-AES256-GCM-SHA384PSK-CHACHA20-POLY1305PSK-AES256-CCMPSK-AES128-GCM-SHA256PSK-AES128-CCMPSK-AES256-CBC-SHAPSK-AES128-CBC-SHA256PSK-AES128-CBC-SHADHE-PSK-AES256-GCM-SHA384DHE-PSK-CHACHA20-POLY1305DHE-PSK-AES256-CCMDHE-PSK-AES128-GCM-SHA256DHE-PSK-AES128-CCMDHE-PSK-AES256-CBC-SHADHE-PSK-AES128-CBC-SHA256DHE-PSK-AES128-CBC-SHAECDHE-PSK-CHACHA20-POLY1305ECDHE-PSK-AES256-CBC-SHAECDHE-PSK-AES128-CBC-SHA256ECDHE-PSK-AES128-CBC-SHARSA-PSK-AES256-GCM-SHA384RSA-PSK-CHACHA20-POLY1305RSA-PSK-AES128-GCM-SHA256RSA-PSK-AES256-CBC-SHARSA-PSK-AES128-CBC-SHA256RSA-PSK-AES128-CBC-SHA
SQL requirements for Full-Text Search
Document Understanding requires the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Document Understanding.
For more info, check this guide on how to add/install features on SQL server. You can also check here all the components that can be added to the SQL Server, which includes also Full-Text Search.
SQL requirements for Insights
Insights does not support Azure AD authentication. If you authenticate using Azure AD, dashboards cannot be loaded and data cannot be fetched from the Microsoft SQL database.
Insights requires SQL Server 2019 or 2022, including support for columnstore index and .json functions. SQL Server Enterprise is recommended due to more efficient threading and scalability.
For Azure SQL, ensure the database is S3 service objective or higher.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to View or Change the Compatibility level of a Database - SQL Server.
The installation validates both conditions and alerts you if minimum requirements are not met.
SQL requirements for Data Service
Data Service requires SQL Server version 2016 or higher.
If you create your own database using SQL Server version 2019 or higher, make sure to grant the following Data Service permissions to your users:
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};
Due to a known issue, you cannot use a custom database name for the Platform database if Process Mining is enabled. If you specify a custom name, the OMS backfill job fails.
To avoid this, use AutomationSuite_Platform as the Platform database name when installing Process Mining.
When you enable Process Mining for installation on Automation Suite 2024.10.3 or higher you can choose to bring either a PostgreSQL database or a Microsoft SQL Server database for AutomationSuite_Airflow.
For Process Mining on Automation Suite 2024.10.3 or higher versions, you are recommended to move to PostgreSQL for the AutomationSuite_Airflow database, as PostgreSQL runs with the latest versions of Apache Airflow. Running the latest version of Airflow ensures you make use of new functionality, performance, and security fixes.
If you choose not to use a PostgreSQL database and keep using a Microsoft SQLServer database, Process Mining on Automation Suite will run with legacy Airflow. Legacy versions of Apache Airflow may lack functionality, performance, and security fixes.
Starting with Process Mining on Automation Suite 2025.10 only PostgreSQL database is supported for the AutomationSuite_Airflow database.
AutomationSuite_Airflow PostgreSQL database
For Process Mining on Automation Suite 2024.10.3 or higher versions, you can choose to use a PostgreSQL database for the AutomationSuite_Airflow database.
Before installing or upgrading to Automation Suite 2024.10.3 or higher, you need to manually create the PostgreSQL database for AutomationSuite_Airflow. The PostgreSQL database for Airflow will not be created automatically by the installer.
When migrating from Microsoft SQL Server to PostgreSQL database data migration is not required. With a correct configuration setup, the database is rebuild when running Sync Airflow.
Supported PostgreSQL versions
PostgreSQL versions 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance.
Hardware requirements
The machine on which the PostgreSQL database for Airflow is installed must meet the following harware requirements.
- Cores: 4
- Memory: 16 GiB
- Storage: 64 GiB
- IOPS: >=500 IOPS
Required permissions
The PostgreSQL Airflow user (or any dedicated database user) must have
- "All Privileges" permissions for the designated Airflow database.
- "all grants" on the server's public schema.
- "search_path" set to "public".
You may need to update PostgreSQL Host-Based Authentication file pg_hba.conf to add the Airflow user to the database access control list and reload the database configuration to apply the changes.
The following code shows an example for setting up a PostgreSQL database.
CREATE DATABASE airflow_db
WITH ENCODING 'UTF8'
LC_COLLATE='en_US.UTF-8'
LC_CTYPE='en_US.UTF-8'
TEMPLATE template0;
CREATE USER airflow_user WITH PASSWORD 'airflow_pass';
GRANT ALL PRIVILEGES ON DATABASE airflow_db TO airflow_user;
-- PostgreSQL 15 requires additional privileges:
GRANT ALL ON SCHEMA public TO airflow_user;
TEMPLATE template0;
The following code shows a database encoding validation example.
SELECT pg_encoding_to_char(encoding) AS encoding
FROM pg_database
WHERE datname = 'airflow_db';
FROM pg_database
Refer to the official Airflow documentation for more information on how to set up a PostgreSQL database for Airflow.
Default server port
The default server port for Airflow database connections with PostgreSQL is 5432. If you are using the PgBouncer connection pooler, it is common to use port 6432.
The following code blocks show some example connection strings for PostgreSQL using port 5432.
Sample connection string:
postgresql+psycopg2://testadmin:<password>@test-cu231009v3-postgresql.postgres.database.azure.com:5432/automationsuite_airflow
Sample connection string for using Kerberos:
Sample connection string for using Managed Identitiy:
postgresql+psycopg2://testmanagedidentity:@test-postgresql-1.postgres.database.azure.com/airflow-ci-sfasaksqacu8524745
The default server port can be configured to use any available port as per your system requirements.
PgBouncer
Since Airflow uses short-lived connections, it is highly recommended to set up PgBouncer. PgBouncer is a lightweight connection pooler for PostgreSQL.
Refer to the official PgBouncer documentation for more information on how to set up PgBouncer.
AutomationSuite_Airflow Microsoft SQL Server database
For the AutomationSuite_Airflow database, Microsoft SQL Server is the only option available for Process Mining on Automation Suite versions 2024.10.2 and earlier. For Process Mining on Automation Suite 2024.10.3 or higher versions, you are recommended to move to PostgreSQL.
If you use Microsoft SQL Server for AutomationSuite_Airflow database, make sure you meet the following requirements.
You must use the default server port 1433 for Airflow database connections. Non-standard SQL Server ports are not supported.
When setting up Microsoft SQL Server make sure that the timezone of the SQL Server machine where the Airflow database is installed, is set to UTC.
AutomationSuite_ProcessMining_Warehouse database
Process Mining on Automation Suite requires a separate Microsoft SQL Server for the AutomationSuite_ProcessMining_Warehouse for data storage for Process Mining process apps.
To ensure proper functioning of Process Mining, it is recommended to use Microsoft SQL Server 2022.
This is an overview of hardware requirements and recommendations for setting up a Microsoft SQL Server database machine for AutomationSuite_ProcessMining_Warehouse.
To calculate the hardware requirements, you need to have an indication of:
- the number of (million) events in your process.
- the number of case and event fields in your output data.
Note:
In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
You can use the UiPath Automation Suite Install Sizing Calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed.
Refer to Hardware requirements for more informations.
The SQL user used in the connection strings must have the db_securityadmin database-level role both during and post-installation to enable per app security on the Process Mining data warehouse SQL Server. For details, see the official Microsoft documentation on Database-level roles.
Refer to Configuring process app security for more information.
It is recommended to enable case sensitivity in table and column names using the following command: ALTER DATABASE AutomationSuite_ProcessMining_Warehouse COLLATE SQL_Latin1_General_CP1_CS_AS This prevents errors when loading data caused by columns with similar names, such as ID and id. It also ensures that textual values differing only in capitalization are treated as distinct. For example:
'activity 1' == 'activity 1''Activity 1' != 'activity 1'
This prevents duplication issues in SQL transformations.
SQL requirements for AI Center
Requirements for AI Center installed on a FIPS 140-2-enabled machine
To install AI Center on a FIPS 140-2-enabled machine, take the following steps:
- Before starting the Automation Suite installation, take the following steps:
- Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
- Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
- Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
nmap -sV -p <port> -vv --script ssl-cert domainnmap -sV -p <port> -vv --script ssl-cert domain
- During the Automation Suite installation, take the following steps:
Append the following values to the AI Center
sql_connection_string_template_jdbcconnection string in theinput.jsonfile:encrypt=true;trustServerCertificate=false;fips=true;.Example:
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"For details on database configuration, see Advanced installation experience and Updating the SQL database.
Add the exported cert from step 1.c. to the trust store of the host machine. For details see Updating the CA Certificates.
SQL requirements for HA
For a high-availability configuration of your SQL Server, select an Always On availability group. For more info, refer to Overview of Always On availability groups.
SQL requirements for Orchestrator
To increase performance, avoid deadlocks, and prevent dirty reads in SQL, make sure that the READ_COMMITTED_SNAPSHOT option is set to ON. To process the same queue with multiple robots, and snapshot isolation is turned on, make sure that the ALLOW_SNAPSHOT_ISOLATION option is set to ON.
Use this query to check if READ_COMMITTED_SNAPSHOT and ALLOW_SNAPSHOT_ISOLATION are enabled or disabled:
SELECT is_read_committed_snapshot_on, snapshot_isolation_state FROM sys.databases
WHERE name like 'PLACEHOLDER'
Make sure to replace PLACEHOLDER with your Orchestrator database name.
If the settings are enabled, the returned value will be 1.
If the settings are disabled, the returned value will be 0. Use this query to enable it:
# To enable READ_COMMITTED_SNAPSHOT
ALTER DATABASE <PLACEHOLDER>
SET READ_COMMITTED_SNAPSHOT ON
# To enable ALLOW_SNAPSHOT_ISOLATION
SET ALLOW_SNAPSHOT_ISOLATION ON
Make sure to replace <PLACEHOLDER> with your Orchestrator database name.
If you use different databases for Test Automation and/or Update Server, READ_COMMITTED_SNAPSHOT and ALLOW_SNAPSHOT_ISOLATION must be enabled on those as well.
- Database creation workflow
- Automatically create the necessary databases
- Bring your own databases
- SQL collation
- SQL server ciphers
- SQL requirements for Full-Text Search
- SQL requirements for Insights
- SQL requirements for Data Service
- SQL requirements for Process Mining
AutomationSuite_AirflowPostgreSQL databaseAutomationSuite_AirflowMicrosoft SQL Server databaseAutomationSuite_ProcessMining_Warehousedatabase- SQL requirements for AI Center
- Requirements for AI Center installed on a FIPS 140-2-enabled machine
- SQL requirements for HA
- SQL requirements for Orchestrator
