Last updated Mar 3, 2026
Output example: prerequisite check
The following example shows the output you may get after checking the infrastructure prerequisites as part of the Automation Suite installation. For details, see Checking the infrastructure prerequisites.
 ℹ️  [empty-app] Creating Argo CD application for component empty-app...
 ℹ️  [empty-app] Waiting for Argo CD application for component empty-app to synchronize...
Ran cluster/ checks...
    Ran ORCHESTRATOR(CLASSIC_FOLDERS) checks...
        ✔ successful
Ran local/ checks...
    Ran ARGO checks...
        ✔ successful
    Ran CONNECTIVITY checks...
        ✔ successful
    Ran DEPLOYMENT_PROFILE checks...
        ✔ successful
    Ran DNS(FQDN=APPS.<FQDN>) checks...
        ✔ successful
    Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...
        ✔ successful
    Ran INGRESS checks...[INGRESS][UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
    Ran NAMESPACE checks...
        ✔ successful
    Ran NETWORK-POLICIES checks...
        ✔ successful
    Ran NODE(CPU >= 8, RAM >= 16G) checks...[NODE(CPU >= 8, RAM >= 16G)][LIST_NODES] Listed 4 nodes
        ✔ [AT_LEAST_ONE_NODE] At least one node found
        ✔ [CPU_USAGE] Node os7140768-7db2g-master-0 has 37.50% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-master-0 has 46.35% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-master-0 has 0.00% of pods in use. Number of pods: 0.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 12.50% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 13.64% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 6.25% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 8.30% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 18.75% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 11.11% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 0.80% of pods in use. Number of pods: 2.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ⚠  [AS_ROBOTS_NODE_EXISTS] No dedicated node found
    Ran OSS(COMPONENT=CERT-MANAGER) checks...
        ✔ successful
    Ran OSS(COMPONENT=GATEKEEPER) checks...
        ✔ successful
    Ran OSS(COMPONENT=ISTIO) checks...
        ✔ successful
    Ran PERMISSION checks...
        ✔ successful
    Ran PRIORITYCLASS checks...
        ✔ successful
    Ran REGISTRY_PULL checks...
        ✔ successful
    Ran RESOURCE checks...
        ✔ successful
    Ran SECRETS checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS) checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA) checks...
        ✔ successful
Ran nodes/ checks...
Ran CONTROLPLANECONNECTIVITY checks...4/4 nodes successful
Ran DNS(FQDN=APPS.<FQDN>) checks...4/4 nodes successful
Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=BA) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=DATASERVICE) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=ORCHESTRATOR) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=PLATFORM) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=TESTMANAGER) checks...4/4 nodes successful
Ran REDIS(PORT=6380) checks...4/4 nodes successful
Ran SQL(PRODUCT=ASROBOTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONHUB, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONOPS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=BA, TYPE=ODBC) checks...4/4 nodes successful
Ran SQL(PRODUCT=DATASERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=INSIGHTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=NOTIFICATIONSERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=PLATFORM, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=TESTMANAGER, TYPE=ADO) checks...4/4 nodes successful
Checks complete!
        ✔ successful
    Ran ARGO checks...
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
     ⚠  [INGRESS]
        ⚠  [UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
        ✔ successful
        ✔ successful
     ⚠  [NODE(CPU >= 8, RAM >= 16G)]
        ✔ [LIST_NODES] Listed 4 nodes
        ✔ [CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
 ✔ 4/4 nodes successful
Checks complete!
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
