Last updated Nov 13, 2025
Log streaming does not work in proxy setups
Log forwarding does not work in Proxy setups because the proxy environment variables were not set in the logging pods.
Solution
  1. Set the http_proxy , https_proxy and no_proxy environment variables. Example:
    export http_proxy=http://<proxy>:3128
    export https_proxy=http://<proxy>:3128
    export no_proxy=<fqdn>,.<fqdn>,10.0.0.0/8,kerberossql.autosuitead.local,kerberospostgres.AUTOSUITEAD.LOCAL,rook-ceph-rgw-rook-ceph.rook-ceph.svc.cluster.local,localhost,127.0.0.1,kubernetes,kubernetes.default,kubernetes.default.svc,kubernetes.default.svc.cluster,kubernetes.default.svc.cluster.local,.svc,.svc.cluster,.svc.cluster.local,.svc.cluster.local.,.uipath.svc.cluster.local,argocd-repo-server,istiod.istio-system.svc,logging-operator-logging-fluentd.logging.svc.cluster.local,.local,.cluster,ai-helper-svc,ai-pkgmanager-svc,ai-deployer-svc,ai-appmanager-svc,ai-trainer-svc,studioweb-backend,studioweb-frontend,studioweb-typecacheexport http_proxy=http://<proxy>:3128
  2. Execute the following script which ingests the environment variables into the logging pods and restarts them.
    #!/bin/bash
    set -euo pipefail
    APP_NAME="logging"
    NAMESPACE="argocd"
    HTTP_PROXY="${http_proxy:-}"
    HTTPS_PROXY="${https_proxy:-}"
    NO_PROXY="${no_proxy:-}"
    # Create a temporary JSON patch
    PATCH_FILE=$(mktemp)
    cat > "$PATCH_FILE" <<EOF
      "spec": {
        "source": {
          "helm": {
            "parameters": [
              { "name": "logging-operator.env[0].name", "value": "http_proxy" },
              { "name": "logging-operator.env[0].value", "value": "${HTTP_PROXY}" },
              { "name": "logging-operator.env[1].name", "value": "https_proxy" },
              { "name": "logging-operator.env[1].value", "value": "${HTTPS_PROXY}" },
              { "name": "logging-operator.env[2].name", "value": "no_proxy" },
              { "name": "logging-operator.env[2].value", "value": "${NO_PROXY}" },
              { "name": "logging-operator.logging.fluentd.envVars[0].name", "value": "http_proxy" },
              { "name": "logging-operator.logging.fluentd.envVars[0].value", "value": "${HTTP_PROXY}" },
              { "name": "logging-operator.logging.fluentd.envVars[1].name", "value": "https_proxy" },
              { "name": "logging-operator.logging.fluentd.envVars[1].value", "value": "${HTTPS_PROXY}" },
              { "name": "logging-operator.logging.fluentd.envVars[2].name", "value": "no_proxy" },
              { "name": "logging-operator.logging.fluentd.envVars[2].value", "value": "${NO_PROXY}" },
              { "name": "logging-operator.logging.fluentbit.envVars[0].name", "value": "http_proxy" },
              { "name": "logging-operator.logging.fluentbit.envVars[0].value", "value": "${HTTP_PROXY}" },
              { "name": "logging-operator.logging.fluentbit.envVars[1].name", "value": "https_proxy" },
              { "name": "logging-operator.logging.fluentbit.envVars[1].value", "value": "${HTTPS_PROXY}" },
              { "name": "logging-operator.logging.fluentbit.envVars[2].name", "value": "no_proxy" },
              { "name": "logging-operator.logging.fluentbit.envVars[2].value", "value": "${NO_PROXY}" }
    EOF
    # Patch the Argo CD Application
    kubectl patch application "$APP_NAME" -n "$NAMESPACE" --type merge --patch-file "$PATCH_FILE"
    # Cleanup
    rm -f "$PATCH_FILE"
    echo "Patched Argo CD Application '$APP_NAME' with proxy parameters."
    echo "Restarting logging pods..."
    kubectl  rollout restart deploy/logging-logging-operator -n logging
    kubectl  rollout restart sts/logging-fluentd -n logging
    kubectl  rollout restart ds/logging-fluentbit  -n logging
    echo "Rollout restart completed"#!/bin/bash
    set -euo pipefail
    APP_NAME="logging"
    NAMESPACE="argocd"
      "spec": {
        "source": {
          "helm": {
            "parameters": [
    EOF
    # Cleanup
    rm -f "$PATCH_FILE"
  • Description
  • Solution
