- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Step 1: Removing old cache keys
- Step 2: Updating AD integration and authentication
- Step 3: Validating the Insights migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Last updated Mar 9, 2026
To configure AD integration, refer to Configuring SSO: Active Directory.
If AD integration and authentication were enabled in the standalone deployment, take the following steps in the Automation Suite cluster:
- Make sure the domain controllers are discoverable by the Automation Suite cluster. If not, use the Kube DNS configuration;
- Configure integrated Windows authentication and Kerberos authentication using keytab file;
- Configure LDAP integration via the Portal under the host admin;
- Configure Windows authentication via the Portal under the host admin;
- Configure LDAPS for secure connection to LDAP.
Note:
The account used for the LDAP integration configuration should only have read access to all trusted domains in the current and trusted forests.
