- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
You can configure the maximum request size in the orchestrator-customconfig config map using a tool such as kubectl.
For details, refer to Custom Orchestrator configuration.
The default value for the maximum request size is 300 MB, but you can edit it in the values.json file. The Orchestrator deployment should restart automatically after this configuration change.
"Kestrel": {
"Limits": {
"MaxRequestBodySize": 314572800
"Kestrel": {
"Limits": {
The values.json file in the orchestrator-customconfig config map may also contain other values, such as AppSettings. You must not remove any other settings when configuring the maximum request size.
"Kestrel": {
"AppSettings": {
"Kestrel": {
"AppSettings": {
