Last updated Mar 26, 2026
input.json example
The following an example shows an input.json file with all the products enabled, as well as the mandatory and optional configuration parameters for Automation Suite. You can use the example as reference and make changes according to your environment requirements.
Note that the minimum UiPath® product selection requires the platform services to be enabled. Make sure to replace FQDNs, hostnames, usernames and passwords, and SQL connection strings with your own configurations.
  "fqdn": "automationsuite.mycompany.com",
  "admin_username": "admin",
  "admin_password": "****",
  "registries": {
    "docker": {
      "url": "registry.mycompany.com",
      "username": "registryuser",
      "password": "****",
      "pull_secret_value": "****"
    "helm": {
      "password": "xxxxxx"
  "sql_connection_string_template": "Server=tcp:sql.mycompany.com,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sql.mycompany.com;Password='g%3qI2x2_%NPZE3Dvdm9Ng_@J_a%YB_sV_B4NncOHMuM%RTE';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
  "sql_connection_string_template_odbc": "SERVER=sql.mycompany.com;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD={g%3qI2x2_%NPZE3Dvdm9Ng_@J_a%YB_sV_B4NncOHMuM%RTE};;Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=sql.mycompany.com",
  "sql_connection_string_template_jdbc": "jdbc:sqlserver://sql.mycompany.com;database=DB_NAME_PLACEHOLDER;user=testadmin@sql.mycompany.com;password={UW1zVTc1NkRZYW5IMVFvbFlzdm1rVldrOFA1Y1RRalkK};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
  "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sql.mycompany.com:<password>@sql.mycompany.com:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=no&Encrypt=yes",
  "postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<passowrd>@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
  "orchestrator": {
    "enabled": true
  "profile": "default",
  "kubernetes_distribution": "openshift",
  "ingress": {
    "gateway_selector": {
      "istio": "ingressgateway"
    "ingress_gateway_secret": "istio-ingressgateway-certs",
    "namespace": "<istio-system>"
  "istioMinProtocolVersion": "TLSV1_3",
  "argocd": {
    "application_namespace": "uipath",
    "project": "uipath"
  "storage_class": "managed-premium",
  "storage_class_single_replica": "managed-premium",
  "exclude_components": [
    "argocd",
    "monitoring",
    "istio",
    "logging",
    "gatekeeper",
    "network-policies",
    "velero",
    "alerts",
    "cert-manager",
    "dapr"
  "sql": {
    "server_url": "sql.mycompany.com",
    "port": "1433",
    "username": "testadmin",
    "password": "****",
    "create_db": true
  "namespace": "uipath",
  "fabric": {
    "redis": {
      "hostname": "redis.mycompany.com",
      "port": 6380,
      "password": "xxxxx=",
      "tls": true
  "external_object_storage": {
    "enabled": true,
    "storage_type": "s3",
    "fqdn": "s3storage.mycompany.com",
    "port": 443,
    "region": "us-east-2",
    "access_key": "***",
    "secret_key": "***"
  "telemetry_optout": true,
  "platform": {
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "action_center": {
    "enabled": true
  "apps": {
    "enabled": true
  "test_manager": {
    "enabled": true
  "dataservice": {
    "enabled": true
  "aicenter": {
    "enabled": true
  "documentunderstanding": {
    "enabled": true
  "processmining": {
    "enabled": true
  "insights": {
    "enabled": true
  "registries": {
    "docker": {
      "password": "****",
    "helm": {
  "orchestrator": {
    "enabled": true
  "ingress": {
  "argocd": {
    "project": "uipath"
    "argocd",
    "monitoring",
    "istio",
    "logging",
    "gatekeeper",
    "network-policies",
    "velero",
    "alerts",
    "cert-manager",
    "dapr"
  "sql": {
    "port": "1433",
    "password": "****",
    "create_db": true
  "fabric": {
    "redis": {
      "port": 6380,
      "tls": true
    "enabled": true,
    "port": 443,
    "secret_key": "***"
  "platform": {
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "action_center": {
    "enabled": true
  "apps": {
    "enabled": true
  "test_manager": {
    "enabled": true
  "dataservice": {
    "enabled": true
  "aicenter": {
    "enabled": true
    "enabled": true
  "processmining": {
    "enabled": true
  "insights": {
    "enabled": true
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
