- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
Reference for configuring Active/Passive disaster recovery topology after installing Automation Suite on OpenShift.
This page provides instructions on how to configure an Active/Passive topology after installing Automation Suite.
For more details, see:
