- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
Last updated May 15, 2026
For instructions on some common operations you might need to perform while installing or configuring Automation Suite, see the following:
- How to uninstall Automation Suite
- How to resolve prereq connectivity check failure on OpenShift 4.16-4.18
- How to deploy Insights in a FIPS-enabled cluster
- How to disable CDI auto-enabling in Nvidia GPU Operator
