- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Monitoring and alerting
- Cluster administration
- Performing database maintenance
- Setting up Kerberos authentication
- Configuring the FQDN post-installation
- Troubleshooting
input.json file and run the uipathctl installer.
Changing the FQDN requires new server certificates. If a new certificate is not available, you have two options: either continue with the new self-signed certificate configured by the installer automatically, or stop the installation and bring in a new CA-issued certificate.
server_certificate field in the
input.json file.
<istio-system> namespace.
Follow the instructions in the note at the end of Configuring Istio and installing the WASM plugin for routing.
Follow the instructions in the note at the end of Installing Dapr.
You must update the
following parameter in the input.json file:
fqdn- update this field with new FQDN that you need to access the cluster.Note: We support only lowercase FQDNs. Do not use uppercase characters in your FQDN.
input.json
configuration required to update the FQDN.
"fqdn": "new-automationsuite.mycompany.com" //this is the fqdn for accessing the automation suite cluster
}To update the FQDN, run the following command:
uipathctl manifest apply input.json --versions version.jsonuipathctl manifest apply input.json --versions version.json --force flag, it will override the warning prompts and perform the FQDN changes directly.
[WARN] You are about to change the FQDN of the Automation Suite Cluster.
Changing the fqdn is a disruptive operation, and it will result in
disconnecting your robots, mobile orchestrator users, ML Activities,
and ML Skills and invalidating any pending user invites.
If you wish to continue type 'yes' and hit enter to continue.[WARN] You are about to change the FQDN of the Automation Suite Cluster.
If you wish to continue type 'yes' and hit enter to continue.The installer also warns you if there is no new valid certificate related to the FQDN. If the certificate validation fails, the installer requires you to provide the new CA-issued certificate or continue with the new self-signed certificate.
[ERROR] Validating certificate... Failed
[ERROR] Certificate doesn't have new-automationsuite.mycompany.com in the SAN
Certificate provided is invalid for the new fqdn, would you like us to configure the new self signed certificate?
If you wish to continue type `yes` and hit enter to continue.************************************************************************************
