- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Running uipathctl
uipathctl is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS, Automation Suite on OpenShift, and Automation Suite on Linux.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
You can install uipathctl on the Linux, macOS, and Windows platforms.
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
For more information, including a complete list of uipathctl operations, see the uipathctl Reference Guide.
Running uipathctl on Linux
To run uipathctl on Linux, take the following steps:
Download the version of the
uipathctlbinary that you are interested in. For instructions, see Downloading the installation packages. -
Uncompress
uipathctland add it to your PATH:tar xzvf uipathctl-linux-amd64.tar.gz chmod +x uipathctl export PATH=$PATH:$(pwd)tar xzvf uipathctl-linux-amd64.tar.gz chmod +x uipathctl export PATH=$PATH:$(pwd) -
Verify if
uipathctlworks:uipathctl versionuipathctl versionThe command prints some version information, as shown in the following example:
Version: 2024.10.0 ...Version: 2024.10.0 ...
Running uipathctl on Windows
To run uipathctl on Windows, take the following steps:
uipathctlbinary that you are interested in. For instructions, see . -
Uncompress
uipathctland add it to your PATH:tar xzvf uipathctl-windows-amd64.tar.gztar xzvf uipathctl-windows-amd64.tar.gzAppend or prepend the
uipathctlbinary folder to yourPATHenvironment variable. -
Verify it is working:
Running uipathctl on MacOS
To run uipathctl on MacOS, take the following steps:
Uncompress
uipathctland add it to your PATH:tar xzvf uipathctl-darwin-amd64.tar.gz chmod +x uipathctl export PATH=$PATH:$(pwd)tar xzvf uipathctl-darwin-amd64.tar.gz chmod +x uipathctl export PATH=$PATH:$(pwd) -
Verify if
Telemetry
By default, telemetry is sent from uipathctl to UiPath® at each command execution. This helps us improve our products and user experience.
To opt out of telemetry, set the UIPATHCTL_TELEMETRY_OPTOUT environment variable to 1:
export UIPATHCTL_TELEMETRY_OPTOUT=1
