- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
Compatibility matrix
Third-party software compatibility matrix for Automation Suite on OpenShift, including supported OpenShift versions.
OpenShift third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on OpenShift.
| Prerequisites for OpenShift | Compatible versions |
| Redis | Version 6, 7, and 85 |
| Microsoft SQL Server | Microsoft SQL Server 2017, 2019 and 2022, Standard and Enterprise editions. For product-specific version dependency, refer to SQL database . |
| PostgreSQL (for Process Mining Airflow database ) Process Mining on Automation Suite 2024.10.3 or higher. | PostgreSQL 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance. |
| OpenShift GitOps Operator | 1.21.1 |
| OpenShift Service Mesh |
| OpenShift Redis Enterprise Operator | 7.8.2-6, 7.4.6-2, 7.22.0-7, 7.22.0-17, 8.0.10-22.0, 8.2.0-12.0 |
| OpenShift Redis Community Operator (by OpsTree Solutions) | 0.15.1 |
| Nvidia GPU Operator (by Nvidia Corporation) |
1 Available starting with Automation Suite 2024.10.9.
2 Available starting with Automation Suite 2024.10.10.
3 Available starting with Automation Suite 2024.10.7.
4 Available starting with Automation Suite 2024.10.8.
5 Support for Redis 7 and 8 is available starting with Automation Suite 2024.10.10.
OpenShift compatibility
To receive UiPath® support for a particular Automation Suite Cumulative Update (CU), you must use both an Automation Suite version and an OpenShift version that are currently supported.
The support calendar for Automation Suite is available in the Product lifecycle section of the Overview guide. For the OpenShift support calendar, refer to the OpenShift documentation.
Updating your OpenShift cluster to a supported version may require updating Automation Suite to a newer CU. For example, if you are on Automation Suite 2024.10.0, the last supported version for your cluster is OpenShift 4.16. When this version reaches its end of life, you must update your cluster to a newer OpenShift version. This also requires updating to a newer Automation Suite CU.
The following table lists the OpenShift versions compatible with each Automation Suite 2024.10.x CU.
| Automation Suite version | Compatible OpenShift versions |
| 2024.10.10 | 4.17, 4.18, 4.19, 4.20, 4.21, 4.22 |
| 2024.10.9 | 4.17, 4.18, 4.19, 4.20, 4.21 |
| 2024.10.8 | 4.17, 4.18, 4.19, 4.20 |
| 2024.10.7 | 4.16, 4.17, 4.18, 4.19 |
| 2024.10.6 | 4.16, 4.17, 4.18, 4.19 |
| 2024.10.5 | 4.16, 4.17, 4.18, 4.19 |
| 2024.10.4 | 4.14, 4.15, 4.16, 4.17 |
| 2024.10.3 | 4.13, 4.14, 4.15, 4.16 |
| 2024.10.2 | 4.13, 4.14, 4.15, 4.16 |
| 2024.10.1 | 4.13, 4.14, 4.15, 4.16 |
| 2024.10.0 | 4.13, 4.14, 4.15, 4.16 |
If you are using OpenShift 4.20 or later, you must configure CSI driver tolerations for ODF. For details, refer to Configuring CSI driver tolerations for ODF 4.20 or later.
