- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Disaster recovery - Installing the secondary cluster
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
Install the secondary Automation Suite cluster for an Active/Passive disaster recovery deployment on OpenShift.
To install the secondary Automation Suite cluster in an Active/Passive deployment, take the following steps.
- Generate or copy the
input.jsonfile from the primary Automation Suite cluster. For details, refer to Generating or copying the configuration file of the primary cluster. - Update the
input.jsonfile with the parameters specific to the secondary Automation Suite cluster. - Resume the Automation Suite installation.
- Switch off inactive products if you use an Active/Passive configuration.
Generate a new input.json file or copy it from the primary cluster.
uipathctl manifest get-revision --namespace <uipath> >> /path/to/new/input.json
Updating the configuration file
Update the input.json file with the parameters specific to the secondary Automation Suite cluster by taking the following steps:
Turn off the unsupported products.
Set all the products that are not supported in multi-site to
false.- For an Active/Passive configuration, disable the products that do not support Active/Passive. For details on Active/Passive support at product level, refer to the table in Disaster recovery - Active/Passive. The following example shows how to disable products:
{ "test_manager": { "enabled": false }, "process_mining": { "enabled": false }, "automation_hub": { "enabled": false }, "insights": { "enabled": false } }{ "test_manager": { "enabled": false }, "process_mining": { "enabled": false }, "automation_hub": { "enabled": false }, "insights": { "enabled": false } }
Note:Make sure that you enable the
platformservice as shown in the following example:"platform": { "enabled": true },"platform": { "enabled": true }, - For an Active/Passive configuration, disable the products that do not support Active/Passive. For details on Active/Passive support at product level, refer to the table in Disaster recovery - Active/Passive. The following example shows how to disable products:
Provide the kubeconfig of the primary cluster. This is required to access a few of the configurations by the secondary cluster made on the primary cluster.
Update the
input.jsonfile with the parameters specific to the secondary cluster. For details, refer to Advanced installation experience.
Resume the installation
Once the parameters in the previous step are provided or modified in the input.json, you can resume the installation. For details, refer to Installing Automation Suite.
You must perform the Automation Suite installation using the uipathctl installer. Note that you do not need to generate a new input.json.
Switching off inactive products
This step is required. Skipping it may cause some services to fail.
If you deployed Automation Suite in Active/Passive mode, switch off the inactive products using the following command.
uipathctl cluster maintenance enable
