- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
Diagrams
The following diagram depicts a regular Active/Passive deployment of Automation Suite:
Requirements
The following table describes the hardware and infrastructure requirements for a multi-site deployment.
| Hardware | Requirements |
| Global Traffic Manager (GTM) | Distributes traffic to your Automation Suite multi-site deployment. The service must be highly available and immune to any deployment site. Additionally, the GTM must be able to configure the health check to isolate the faulty site quickly. The GTM is not mandatory but is recommended for a quick switchover. When configuring the Global Traffic Manager (GTM) for Active/Passive deployments, make sure to use /orchestrator_/api/status as the health endpoint. This is critical for effective disaster recovery management. |
| Load balancer | Every site needs a local load balancer that can load-balance the traffic to any node configured in the same site. |
| Node | Both sites must have identical number of nodes and for each site you must configure the cluster and nodes using the documentation provided in the Kubernetes cluster and nodes page. For more details, refer to Automation Suite Install Sizing Calculator. |
| SQL database | An external SQL server is required to store the data. For disaster recovery, you need Always On Availability Groups (or Amazon RDS's MSSQL with ReadReplica) with a primary SQL server in Site 1 and at least one secondary physically SQL Server (ReadReplica) located in Site 2 with data sync enabled. There is also a SQL listener deployed on top of the SQL server. Both clusters are configured to use the address of the same listener. |
| Objectstore | Any files or packages uploaded to products are stored in the objectstore. For greater resilience to failure, Automation Suite deployments require an external objectstore. For effective disaster recovery, two objectstore instances are required; one instance must be situated in each data center. At any given time, only one objectstore instance must be actively used for reading and writing by both clusters. This process must be complemented by asynchronous replication to the secondary instance. |
Load balancer and DNS configuration
This section outlines the DNS architecture and routing logic for a system designed to operate in both normal and disaster recovery scenarios.
DNS architecture
To facilitate traffic management and cluster-specific service accessibility, two tiers of DNS configuration are employed.
- FQDN: The application FQDN is the primary domain used by end users to access the application interface. This value corresponds to the
fqdnfield ininput.json. For more details, refer to Active/Passive configurations. - Cluster-specific FQDNs: In addition to the main application FQDN, each cluster requires its own FQDN for administrative and monitoring tools. This value is defined under the
cluster_fqdnfield in each cluster'sinput.json. For more details, refer to Active/Passive configurations. - Subdomains: For comprehensive service access, a set of subdomains is configured for both the application FQDN and each cluster-specific FQDN. These include:
- FQDN:
apps.<domain>- used by Apps.insights.<domain>- used by for Insights.
- Cluster-specific FQDN:
alm.<domain>- used by ArgoCD and for deployment management. This is required for both Active (primary) and Passive (secondary) clusters.monitoring.<domain>- used for observability and alerts. This is required for both Active (primary) and Passive (secondary) clusters.All subdomains are directed to the same load balancer as their respective root domain to maintain consistency and ease of routing.
- FQDN:
DNS routing logic
The DNS routing logic ensures that user traffic is directed to the appropriate load balancer depending on the system state
- either during normal operation or disaster recovery.
Normal Operations (Primary Cluster is Active) In standard operation mode, DNS routes traffic as described in the following table:
FQDN type Routing target FQDN Primary Cluster Load Balancer Primary Cluster FQDN Primary Cluster Load Balancer Secondary Cluster FQDN Secondary Cluster Load Balancer -
Disaster Recovery (Secondary Cluster is Active) If the primary cluster fails, the system enters disaster recovery mode. In this state, DNS is adjusted to ensure service continuity:
FQDN type Routing target FQDN Secondary Cluster Load Balancer Primary Cluster FQDN Primary Cluster Load Balancer*(unchanged)* Secondary Cluster FQDN Secondary Cluster Load Balancer*(unchanged)*
