Quick links
Quick-reference links for Disaster Recovery prerequisites, new Automation Suite setup steps, and converting existing installations in Automation Suite.
Before you begin​
The following table lists the prerequisites for getting started with Disaster Recovery.
StepDetails
Find out the essentials on Disaster Recovery - Active/Passive deploymentsOverview
Learn more on the architecture of Disaster Recovery - Active/Passive deploymentsBasic architecture considerations
Frequently asked questionsQ&A: Disaster Recovery
Installing a new Automation Suite setup​
The following table lists the steps to install a new Automation Suite setup.
Step
Details
Install the primary server
Generate the input.json file using the interactive installer.
Update the input.json file.
Resume the installation.
Install the secondary server
Copy or generate the input.json from the primary server.
For Active/Passive configurations, make sure to switch off the products in the passive cluster. For details, refer to Switching off inactive products.
Converting an existing setup​
The following table lists the steps to convert an existing Automation Suite installation.
Step
Details
Converting an existing installation to a Disaster Recovery - Active/Passive setup
Convert the standalone Automation Suite cluster into the primary cluster
Install secondary Automation Suite cluster.
Switching to the secondary cluster
N/A
Upgrading an Active/Passive deployment
N/A
Backing up and restoring an Active/Passive deployment
N/A
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
