Last updated Mar 3, 2026
Step 1: Restoring the standalone product database
Here we introduce a way to use SQL Server Management Studio (SSMS) to restore the database of a standaloneproduct to the Automation Suite SQL Server instance. For details on downloading and installing SQL Server Management Studio, see Migration prerequisites.
  1. In SQL Server Management Studio connect to the standalone product database, select Tasks, then choose Deploy Database to Azure SQL.
    docs image
  2. Select Connect to connect to the Automation Suite SQL database. Provide the new database name. Choose the directory to store the temporary database file.
    docs image
  3. Wait for the deployment to complete.
    docs image
  4. Record the connection string for the restored standalone product database in Automation Suite.
Restoring the standalone Orchestrator database on EKS
If you migrate to Automation Suite on EKS, you cannot directly restore the Orchestrator database to the Azure SQL database. You must first back up the standalone Orchestrator database to a file and then restore to the RDS database.
If Orchestrator and Identity share their their database, you can skip step 4. If they have separate databases, you must back them up separately.
  1. Log into the standalone machine and log into SQL Server using SSMS.
  2. Back up the standalone Orchestrator database:
    1. Go to Databases, right-click the Orchestrator database, select Tasks, and select Back Up.
    docs image 2. Confirm the backup path.
    docs image 3. Complete the backup.
    docs image
  3. Restore the standalone Orchestrator database to RDS on the Automation Suite on EKS instance on the standalone machine
    1. Upload the backed up bak file to S3 bucket.
      aws s3 cp <local-file-path> s3://haonan-msi-asair-migration-bucket/<filename>
      Sample:
      aws s3 cp "C:\Program Files\Microsoft SQL Server\MSSQL15.SQLEXPRESS\MSSQL\Backup\20230401_0614.bak" s3://haonan-msi-asair-migration-bucket/20230401_0614.bak --region us-west-2
    2. Grant permission to the restored database on AWS.
Granting permissions to the restored database on AWS
  1. Go to IAM, and create a new role with AWSBackupServiceRolePolicyForRestores permissions.
    docs image
  2. Go to RDS and select Option groups:
    1. Create a group and provide the following details:
      • Name: SqlServerBackupRestore
      • Description: xxx
      • Engine: Select your DB engine
      • Major Engine Version: Select version of your DB instance.
    2. Select Create.
      docs image
    3. Select the name of created group to edit it as follows:
      1. Select Add.
      2. Select SQLSERVER_BACKUP_RESTORE.
      3. Select the IAM role you created in the previous steps.
      4. Select Immediately to schedule instant change.
      docs image
    4. Back to RDSDatabases and select your instance.
      1. Select Modify.
      2. Select Option group you created in the previous step.
      3. Select Next.
      4. Select Apply immediately (it should not cause service downtime).
      5. Apply changes by selecting Modify DB instance.
      6. If you have connection to database from SQL Management Studio, close it and connect again.
  3. Follow AWS documentation to database backed up bak file to AWS S3 bucket. Sample command:
    exec msdb.dbo.rds_restore_database
        @restore_db_name='UiPath_20230531',
        @s3_arn_to_restore_from='arn:aws:s3:::haonan-msi-asair-migration-bucket/20230401_0614.bak',
        @with_norecovery=0,
        @with_norecovery=0,
  • Restoring the standalone Orchestrator database on EKS
  • Granting permissions to the restored database on AWS
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
