Configuring CSI driver tolerations for ODF 4.20 or later
Configure CSI driver tolerations for ODF 4.20 or later in Automation Suite on OpenShift to schedule Ceph CSI nodeplugins correctly.
OpenShift Data Foundation (ODF) 4.20 uses rook 1.18, which factors out Ceph CSI drivers into a separate operator. As a result, the previous method of passing tolerations through the CSI_PLUGIN_TOLERATIONS configmap no longer works. To ensure that Ceph CSI nodeplugins are scheduled on the correct nodes, you must explicitly add tolerations to the Ceph CSI nodeplugins.
Solution
After the storagecluster has been successfully deployed, take the following steps:
  1. Save the following configuration to a YAML file:
    apiVersion: csi.ceph.io/v1
    kind: Driver
    metadata:
      namespace: openshift-storage
    spec:
      nodePlugin:
        tolerations:
        - effect: NoSchedule
          key: node.ocs.openshift.io/storage
          operator: Equal
          value: "true"
          key: serverless.robot
          operator: Equal
          value: "present"
          key: node-role.kubernetes.io/control-plane
          operator: Exists
          key: uipath
          operator: Exists
    kind: Driver
    metadata:
    spec:
      nodePlugin:
        tolerations:
          operator: Equal
          value: "true"
          operator: Equal
          value: "present"
          operator: Exists
          key: uipath
          operator: Exists
    kind: Driver
    metadata:
    spec:
      nodePlugin:
        tolerations:
          operator: Equal
          value: "true"
          operator: Equal
          value: "present"
          operator: Exists
          key: uipath
          operator: Exists
    kind: Driver
    metadata:
    spec:
      nodePlugin:
        tolerations:
          operator: Equal
          value: "true"
          operator: Equal
          value: "present"
          operator: Exists
          key: uipath
          operator: Exists
  2. Apply the configuration by running the following command:
    oc apply -f <filename>.yaml
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
