Last updated Mar 3, 2026
Running the diagnostics tool
The Automation Suite diagnostics tool runs a set of checks to generate a report on the cluster health, which you can analyze to identify issues and their potential root causes. The tool helps you find common issues, such as lost database connectivity or invalid or expired credentials.
The Automation Suite diagnostics tool is available in both uipathctl and uipathtools, which you can download on your management machine.
For download instructions, see uipathctl and uipathtools.
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands. The tool is backwards compatible and works with any of the supported Automation Suite versions. We recommend using uipathtools as the first step if you face any issue.
Quick validation
Quick validation
The check and test commands provide quick insights into the state of the cluster without running a deep analysis.
  • check relies on the ArgoCD health and sync status and does not modify any state in the cluster
  • test looks into the applications, deployment, or pods and temporarily mutates the state of the cluster to provide you with those insights.
Health check
To run a health check, use one of the following commands, depending on the CLI tool you use:
  • If you use uipathctl, run:
    ./uipathctl health check
  • If you use uipathtools, run:
    ./uipathtools health check
Note:
Use the --namespace flag (optional) to provide the namespace where uipath resources are installed. You need to use the flag only if the installation is not in the uipath namespace.
Sample output of the generated report:
Checks run on cluster/[NOTIFICATIONSERVICE][NOTIFICATIONSERVICE_HEALTH] Application is healthy and in sync
 ✔ [ACTION_CENTER][ACTIONCENTER_HEALTH] Application is healthy and in sync
 ❌ [SYNC][namespace:"uipath" | kind:"Application" | name:"dataservice"] Application health check failed: health status is Progressing and sync status is Synced
 ✔ [RELOADER][RELOADER_HEALTH] Application is healthy and in sync
 ❌ [POD][LIST_NAMESPACES] Retrieved 25 namespaces to check pod health
    ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-v5krg cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
    ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-xs9t5 cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
    ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-taskrunner-787df76c74-98h5l cannot mount volume: MountVolume.SetUp failed for volume "external-storage-creds" : secret "dataservice-external-storage-secret" not found
 ✔ [ISTIO][LIST_PODS] Found 2 pods for Istio
    ✔ [ISTIOD_EXISTS] The Istio pods are present and running version -[ISTIOD_READY] Istio pods are healthy
 ✔ [AIEVENTS][AIEVENTS_HEALTH] Application is healthy and in sync
 ❌ [DATASERVICE][DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced
 ✔ [PLATFORM][PLATFORM_HEALTH] Application is healthy and in sync
 ✔ [WEBHOOK][WEBHOOK_HEALTH] Application is healthy and in sync
 ✔ [NOTIFICATIONSERVICE]
    ✔ [NOTIFICATIONSERVICE_HEALTH] Application is healthy and in sync
 ✔ [ACTION_CENTER]
    ✔ [ACTIONCENTER_HEALTH] Application is healthy and in sync
 ❌ [SYNC]
    ❌ [namespace:"uipath" | kind:"Application" | name:"dataservice"] Application health check failed: health status is Progressing and sync status is Synced
 ✔ [RELOADER]
    ✔ [RELOADER_HEALTH] Application is healthy and in sync
 ❌ [POD]
    ✔ [LIST_NAMESPACES] Retrieved 25 namespaces to check pod health
 ✔ [ISTIO]
    ✔ [LIST_PODS] Found 2 pods for Istio
    ✔ [ISTIOD_READY] Istio pods are healthy
 ✔ [AIEVENTS]
    ✔ [AIEVENTS_HEALTH] Application is healthy and in sync
 ❌ [DATASERVICE]
    ❌ [DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced
 ✔ [PLATFORM]
    ✔ [PLATFORM_HEALTH] Application is healthy and in sync
 ✔ [WEBHOOK]
    ✔ [WEBHOOK_HEALTH] Application is healthy and in sync
By default, the health check command checks the health of all the components. However, it also allows you to check strictly the components that you are interested in:
  • If you want to exclude components from the execution, use the --excluded flag.
    For example, if you do not want to check the health of SQL, run the following command:
    ./uipathctl health check --excluded SQL
    The command checks the health of all components except for SQL.
  • If you want to include only certain components in the execution, use the --included flag.
    For example, if you only want to check the health of DNS and objectstore, run the following command:
    ./uipathctl health check --included DNS,OBJECTSTORAGE
Note:
You can find the names of the components you can include or exclude from the health checks . In the example, the first word on each outdented line represents the component name. For example: SQL, OBJECTSTORE, DNS, etc.
Analyzing the logs
  1. After running a check health check, the logs show that health check for the Data Service application failed.
    ❌ [DATASERVICE]
  2. After further investigation, it becomes clear that the Data Service application failed because the dataservice-runtime-8f5bb7d56-v5krg and dataservice-taskrunner-787df76c74-98h5l pods are in a failed state. If you analyze further, you can find that the missing dataservice-external-storage-secret is missing.
    ❌ [POD]
  3. To fix this issue, ensure that you provided the correct credentials for the objectstore in the input.json. For details, see Updating credentials.
Health test
To run a health test, use one of the following commands, depending on the CLI tool you use:
    ./uipathctl health test
    ./uipathtools health test
Note:
Checks run on cluster/[ACTION_CENTER][CREATE_NAMESPACE] Created namespace prereqk6b72
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqk6b72
    ✔ [CREATE_NAMESPACE] Created namespace prereqbxjx8
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqbxjx8
    ✔ [CREATE_NAMESPACE] Created namespace prereq8zvw4
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq8zvw4
 ✔ [DATASERVICE][CREATE_NAMESPACE] Created namespace prereqxwlsb
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqxwlsb
    ✔ [CREATE_NAMESPACE] Created namespace prereq5szsn
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq5szsn
 ✔ [APPS][CREATE_NAMESPACE] Created namespace prereq9z6nb
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq9z6nb
    ✔ [CREATE_NAMESPACE] Created namespace prereq6v7lm
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq6v7lm
    ✔ [CREATE_NAMESPACE] Created namespace prereqxxn5v
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqxxn5v
 ✔ [AUTOMATION_HUB][CREATE_NAMESPACE] Created namespace prereq4jkbt
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq4jkbt
 ✔ [TEST_MANAGER][CREATE_NAMESPACE] Created namespace prereqnvvpc
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqnvvpc
 ✔ [ORCHESTRATOR][CREATE_NAMESPACE] Created namespace prereq8pf2f
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq8pf2f
    ✔ [CREATE_NAMESPACE] Created namespace prereq4w4v4
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq4w4v4
    ✔ [CREATE_NAMESPACE] Created namespace prereqkzwqg
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqkzwqg
 ✔ [INSIGHTS][CREATE_NAMESPACE] Created namespace prereqqmgjc
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqqmgjc
    ✔ [CREATE_NAMESPACE] Created namespace prereq4vnjx
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq4vnjx
    ✔ [CREATE_NAMESPACE] Created namespace prereqgtg9g
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqgtg9g
 ✔ [AUTOMATION_OPS][CREATE_NAMESPACE] Created namespace prereqgkkrz
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqgkkrz
 ✔ [AICENTER][CREATE_NAMESPACE] Created namespace prereqdls88
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereqdls88
    ✔ [CREATE_NAMESPACE] Created namespace prereq6m7x9
    ✔ [CREATE_POD] Created test pod curl-pod in namespace prereq6m7x9
 ✔ [ACTION_CENTER]
    ✔ [CREATE_NAMESPACE] Created namespace prereqk6b72
 ✔ [DATASERVICE]
    ✔ [CREATE_NAMESPACE] Created namespace prereqxwlsb
 ✔ [APPS]
    ✔ [CREATE_NAMESPACE] Created namespace prereq9z6nb
 ✔ [AUTOMATION_HUB]
    ✔ [CREATE_NAMESPACE] Created namespace prereq4jkbt
 ✔ [TEST_MANAGER]
    ✔ [CREATE_NAMESPACE] Created namespace prereqnvvpc
 ✔ [ORCHESTRATOR]
    ✔ [CREATE_NAMESPACE] Created namespace prereq8pf2f
 ✔ [INSIGHTS]
    ✔ [CREATE_NAMESPACE] Created namespace prereqqmgjc
 ✔ [AUTOMATION_OPS]
    ✔ [CREATE_NAMESPACE] Created namespace prereqgkkrz
 ✔ [AICENTER]
    ✔ [CREATE_NAMESPACE] Created namespace prereqdls88
By default, the health test command executes health tests on all the components. However, it also allows you to check strictly the components that you are interested in:
    ./uipathctl health test --excluded SQL
    ./uipathctl health test --included DNS,OBJECTSTORAGE
Note:
You can find the names of the components you can include or exclude from the health tests . In the example, the first word on each outdented line represents the component name. For example: SQL, OBJECTSTORE, DNS, etc.
Note:
If you compare the output of the check and test commands for the Data Service application, you can see that the former validates the health of the application, whereas the latter checks the routing.
Known issue
You might get an error message similar to the following sample. You can ignore it as no action is required from your side.
E0621 23:32:56.426321   24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.426392   24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.444420   24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.446150   24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
E0621 23:32:56.513357   24470 reflector.go:138] external/io_k8s_client_go/tools/cache/reflector.go:167: Failed to watch *v1.Pod: context deadline exceeded
Deep validation
Deep validation
The diagnose command provides deep insights into the state of the cluster. It helps you identify issues at all levels, such as SQL, objectstore, node, secret, Istio, networking etc.
  • It covers both the check and test commands.
  • It runs the prerequisites checks performed before the Automation suite installation, to validate changes to the environment configuration that were made post-installation and that can be the potential cause of the issue.
  • It runs on the all the nodes to gather any node-specific issues, such as resource unavailability, any network interference, etc.
To run a diagnostic check, use one of the following commands, depending on the CLI tool you use:
    ./uipathctl health diagnose input.json --versions versions.json
    ./uipathtools health diagnose input.json --versions versions.json
Note:
Use the--namespace flag (optional) to provide the namespace where uipath resources are installed. You need to use the flag only if the installation is not in the uipath namespace.
Ran cluster/ checks...[DATASERVICE][DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced
    ❌ [ISTIO][ISTIO_SYNC_STATUS] Istio sync is up-to-date
       ❌ [ISTIO_ENVOY_CONFIG_STATUS] Istio Envoy configs are not healthy: Error [IST0101] (VirtualService uipath/du-platform-vs) Referenced host:port not found: "aistorage:5000"[ISTIO_SERVICEMESH_VALIDATION_GET_REGISTRY_FQDN] Successfully retrieved registry url
       ✔ [ISTIO_SERVICEMESH_VALIDATION_GET_CLUSTER_FQDN] Successfully retrieved cluster fqdn
       ✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_DEPLOYMENT] Successfully created the test deployment istio-validation-deployment
       ✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_SERVICE] Successfully created the test service istio-validation-service
       ✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_GATEWAY] Successfully created the test gateway istio-validation-gateway
       ✔ [ISTIO_SERVICEMESH_VALIDATION_CREATE_TEST_VIRTUALSERVICE] Successfully created the test virtual service istio-validation-vs
       ✔ [ISTIO_SERVICEMESH_VALIDATION_URL_ACCESS] Success exposing the service via servicemesh
       ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/ah-tenant-service-sync-insights-data-job-28122960-p6rzg cannot mount volume: MountVolume.SetUp failed for volume "ah-insights-secrets" : failed to sync secret cache: timed out waiting for the condition
       ❌ [CANNOT_MOUNT_VOLUME] Pod uipath/dataservice-runtime-8f5bb7d56-v5krg cannot mount volume: (combined from similar events): Unable to attach or mount volumes: unmounted volumes=[external-storage-creds], unattached volumes=[workload-socket is-secrets openssl istio-podinfo temp-location cert-location istio-data external-storage-creds workload-certs istio-envoy java domain-cert-config edk2 credential-socket tmp additional-ca-cert-config pem istiod-ca-cert istio-token app-secrets ceph-storage-creds]: timed out waiting for the condition
       ❌ [POD_UNHEALTHY] Latest event for pod uipath/du-documentmanager-dm-maintenance-cron-28122960-4sm5z: Error: failed to sync configmap cache: timed out waiting for the condition
    Ran MAINTENANCE checks...
        ✔ successful
    Ran NODE checks...
        ✔ successful
    Ran REPLICAS checks...
        ✔ successful
Checks complete!
Checks complete!
Ran local/ checks...
    Ran ARGO checks...
        ✔ successful
    Ran CONNECTIVITY checks...[CONNECTIVITY][NETWORK_TEST_SETUP] Failed to create the network test infrastructure: failed to create echo-host-role role: error creating role: roles.rbac.authorization.k8s.io "network-prereq-9thz9-echo-host-role" is forbidden: user "system:serviceaccount:os7140768:uipathadmin" (groups=["system:serviceaccounts" "system:serviceaccounts:os7140768" "system:authenticated"]) is attempting to grant RBAC permissions not currently held:
{APIGroups:["security.openshift.io"], Resources:["securitycontextconstraints"], ResourceNames:["hostnetwork-v2"], Verbs:["use"]}
    Ran DEPLOYMENT_PROFILE checks...
        ✔ successful
    Ran DNS(FQDN=APPS.<FQDN>) checks...
        ✔ successful
    Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...
        ✔ successful
    Ran INGRESS checks...
        ✔ successful
    Ran NAMESPACE checks...
        ✔ successful
    Ran NETWORK-POLICIES checks...
        ✔ successful
    Ran NODE(CPU >= 8, RAM >= 16G) checks...[NODE(CPU >= 8, RAM >= 16G)][LIST_NODES] Listed 4 nodes
        ✔ [AT_LEAST_ONE_NODE] At least one node found
        ✔ [CPU_USAGE] Node os7140768-7db2g-master-0 has 62.50% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-master-0 has 49.09% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-master-0 has 0.00% of pods in use. Number of pods: 0.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 18.75% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 22.31% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 7.60% of pods in use. Number of pods: 19.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 18.75% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 26.30% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 7.20% of pods in use. Number of pods: 18.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 18.75% CPU usage
        ✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 17.91% memory usage
        ✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 6.80% of pods in use. Number of pods: 17.00 max allowed: 250.00[CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8[RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ⚠  [AS_ROBOTS_NODE_EXISTS] No dedicated node found
    Ran OSS(COMPONENT=CERT-MANAGER) checks...
        ✔ successful
    Ran OSS(COMPONENT=GATEKEEPER) checks...
        ✔ successful
    Ran OSS(COMPONENT=ISTIO) checks...
        ✔ successful
    Ran PERMISSION checks...
        ✔ successful
    Ran PRIORITYCLASS checks...
        ✔ successful
    Ran REGISTRY_PULL checks...
        ✔ successful
    Ran RESOURCE checks...
        ✔ successful
    Ran SECRETS checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS) checks...
        ✔ successful
    Ran STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA) checks...
        ✔ successful
    Ran ORCHESTRATOR(CLASSIC_FOLDERS) checks...
        ✔ successful
Ran nodes/ checks...
Ran CONTROLPLANECONNECTIVITY checks...4/4 nodes successful
Ran DNS(FQDN=APPS.<FQDN>) checks...4/4 nodes successful
Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=BA) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=DATASERVICE) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=ORCHESTRATOR) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=PLATFORM) checks...4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=TESTMANAGER) checks...4/4 nodes successful
Ran REDIS(PORT=6380) checks...4/4 nodes successful
Ran SQL(PRODUCT=ASROBOTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONHUB, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=AUTOMATIONOPS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=BA, TYPE=ODBC) checks...4/4 nodes successful
Ran SQL(PRODUCT=DATASERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=INSIGHTS, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=NOTIFICATIONSERVICE, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=PLATFORM, TYPE=ADO) checks...4/4 nodes successful
Ran SQL(PRODUCT=TESTMANAGER, TYPE=ADO) checks...4/4 nodes successful
    ❌ [DATASERVICE]
    ❌ [ISTIO]
       ✔ [ISTIO_SYNC_STATUS] Istio sync is up-to-date
       ✔ [ISTIO_SERVICEMESH_VALIDATION_GET_REGISTRY_FQDN] Successfully retrieved registry url
    ❌ [POD]
    ❌ [SYNC]
        ✔ successful
    Ran NODE checks...
        ✔ successful
        ✔ successful
Checks complete!
Checks complete!
    Ran ARGO checks...
        ✔ successful
     ⚠  [CONNECTIVITY]
        ⚠  [NETWORK_TEST_SETUP] Failed to create the network test infrastructure: failed to create echo-host-role role: error creating role: roles.rbac.authorization.k8s.io "network-prereq-9thz9-echo-host-role" is forbidden: user "system:serviceaccount:os7140768:uipathadmin" (groups=["system:serviceaccounts" "system:serviceaccounts:os7140768" "system:authenticated"]) is attempting to grant RBAC permissions not currently held:
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
     ⚠  [NODE(CPU >= 8, RAM >= 16G)]
        ✔ [LIST_NODES] Listed 4 nodes
        ✔ [CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8
        ✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
        ✔ successful
 ✔ 4/4 nodes successful
Note:
The aforementioned sample is trimmed down. Actual logs have more information. You can notice that the diagnose command runs at multiple levels, such as infrastructure, networking, storage, pods, DNS etc.
Analyzing the logs
There are two potential issues that you can notice in the previous logs:
  • Istio has a bad configuration, which can cause issues accessing the Document Understanding platform:
    ❌ [ISTIO]
  • Data Service is unavailable. See Ceph in the code example.
    ❌ [DATASERVICE]
Known issues
Additional utilities
Additional uitilities
All the Automation Suite diagnostics tool commands (check, test, and diagnose) support additional filtering and output format.
Filtering
FiltersDescriptionUsages
--includedComma-separated list of the services to include in the validation./uipathctl health diagnose input.json --versions versions.json --included ISTIO,INSIGHTS
This command runs the diagnose only against Istio and Insights.
--excludedComma-separated list of the services to exclude from the validation./uipathctl health test --excluded ISTIO,INSIGHTS
This command runs the test in the entire cluster, except Istio and Insights.
Output format
The Automation Suite diagnostics tool can generate reports in multiple formats: json, yaml, text, and junit. You can pass these values to any of the command via the --output flag. These output formats are handy when you want to leverage these tools to build your own troubleshooting framework on top of them.
Example usages
UsageExample Output
./uipathctl health check --included DATASERVICE --output json
./uipathtools health check --included DATASERVICE --output json
  "cluster/": {
    "DATASERVICE": [
        "name": "DATASERVICE_HEALTH",
        "description": "Application health check failed: health status is Progressing and sync status is Synced",
        "status": "failed"
  "cluster/": {
    "DATASERVICE": [
        "status": "failed"
./uipathctl health check --included DATASERVICE --output yaml
./uipathtools health check --included DATASERVICE --output yaml
? locationType: cluster
: DATASERVICE:
  - name: DATASERVICE_HEALTH
    description: 'Application health check failed: health status is Progressing and sync status is Synced'
    status: failed
: DATASERVICE:
    status: failed
./uipathctl health check --included DATASERVICE --output text
./uipathtools health check --included DATASERVICE --output text
Checks run on cluster/[DATASERVICE][DATASERVICE_HEALTH] Application health check failed: health status is Progressing and sync status is Synced
❌ [DATASERVICE]
./uipathctl health check --included DATASERVICE --output junit
./uipathtools health check --included DATASERVICE --output junit
<testsuite name="Health" tests="1" errors="0" failures="1" time="0" timestamp="2023-06-22T01:59:08.313362+05:30" hostname="">
  <testcase name="DATASERVICE_HEALTH" classname="" time="0">
    <failure message="Application health check failed: health status is Progressing and sync status is Synced" type="">
    </failure>
  </testcase>
</testsuite>
    </failure>
  </testcase>
</testsuite>
  • Quick validation
  • Quick validation
  • Health check
  • Health test
  • Deep validation
  • Deep validation
  • Additional utilities
  • Additional uitilities
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
