Step 6: Updating the migrated product connection strings
Downloading uipathctl
To download uipathctl, refer to Downloading the installation packages.
Generating the configuration file
To generate the input.json configuration file, take one of the following steps:
  • Option A: Generate the latest input.json file:
    uipathctl manifest get-revision | Out-File -Encoding ascii input.json
  • Option B: List all the past input.json files and determine which one you want to choose:
    uipathctl manifest list-revisions
Replacing the connection string and starting the installation
  1. Move the versions.json file to the same directory as input.json. You can get versions.json from the Automation Suite installation folder.
  2. Provide the new connection strings for the installed products.
    • To provide the restored connection string to the Orchestrator service, add or update sql_connection_str under orchestrator in the input.json file:
      "orchestrator": {
        "sql_connection_str": "<restored orchesrator connection string>",   (added line)
        "enabled": true
      "orchestrator": {
        "enabled": true
    • If Test Automation tables are placed inside the standalone Orchestrator database, you can also add the same connection string for Test Automation feature inside the input.json file:
      "orchestrator": {
        "testautomation": {
          "enabled": true,
          "sql_connection_str": "<restored orchestrator connection string>"
        "sql_connection_str": "<restored orchestrator connection string>",   (added line)
        "enabled": true
      "orchestrator": {
        "testautomation": {
          "enabled": true,
        "enabled": true
    • If Test Automation tables are not placed inside the standalone Orchestrator database, add the connection string for restored Test Automation database inside the file:
      "orchestrator": {
        "testautomation": {
          "enabled": true,
          "sql_connection_str": "<restored test_automation connection string>"
        "enabled": true
      "orchestrator": {
        "testautomation": {
          "enabled": true,
        "enabled": true
    • To provide the restored connection string to the Insights service, add or update sql_connection_str under insights in the input.json file.
      "insights": {
         "sql_connection_str": "<restored connection string>",   (added line)
         "enabled": true }
      "insights": {
         "enabled": true }
    • To provide the restored connection string to the Test Manager service, add or update sql_connection_str under test_manager in the input.json file.
      "test_manager": {
        "sql_connection_str": "<restored test_manager connection string>",   (added line)
        "enabled": true
      "test_manager": {
        "enabled": true
  3. Update the input.json file by running the installer.
    • To migrate Orchestrator only, run the following command:
      uipathctl manifest apply input.json --only orchestrator --versions versions.json
    • To migrate Insights only, run the following command:
      uipathctl manifest apply input.json --only insights --versions versions.json
    • To migrate Test Manager only, run the following command:
      ./bin/uipathctl manifest apply cluster_config.json --only test_manager --versions versions/helm-chart.json
      Note:
      If you run the command on Windows, replace uipathctl with .\uipathctl.exe in the command.
  4. Remap the organization IDs in the Insights tables. For more details, refer to Remapping the organization IDs.
  5. Run the Test Manager migration script and provide the necessary parameters:
    ./testmanager_migrator.sh -k <encryption_key> -y
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
