Last updated Nov 13, 2025
Overriding cluster-level storage configuration
Orchestrator supports the following storage configurations:
  • Cluster-level storage configuration
  • Orchestrator-level storage configuration
We recommend using the cluster-level configuration paired with external storage. This allows Orchestrator to automatically detect and use the settings, eliminating the need for additional configuration.
Configuring Azure/Amazon S3 storage buckets
To configure the Orchestrator-level storage provider, update the Orchestrator parameters by taking the following steps. For more details, see Configuring the Orchestrator parameters.
  1. In the configuration file, under orchestrator, add the legacy_storage_provider section that contains the storage type and connection string, as shown in the following example:
    "orchestrator": {
      "enabled": true,
      "legacy_object_storage": {
        "type": "Azure",
        "connection_string": "DefaultEndpointsProtocol=https;AccountName=usr;AccountKey=...;EndpointSuffix=core.windows.net"
    }"orchestrator": {
      "enabled": true,
        "type": "Azure",
  2. Set the desired provider using the type parameter. The possible values are: Azure, AWS, and Minio. A few considerations:
    • The storage.type parameter values are case-sensitive.
    • FileSystem storage configuration is not supported.
  3. Add the connection string for the storage provider using the connection_string parameter. For details on the connection strings format, see the Storage.Location section of UiPath.Orchestrator.dll.config.
Note:
Orchestrator web browser access to Amazon and Azure storage buckets could be restricted due to the same-origin policy on the provider side. To successfully access the content of such a bucket, you must configure the respective provider to allow cross-origin requests from Orchestrator. For instructions, see CORP/CSP configuration.
Uploading files to storage
Files can be uploaded to the storage using the uipathctl command line tool. To do that, use the following command:
uipathctl config orchestrator upload [parameters]uipathctl config orchestrator upload [parameters]
ParameterDescription
--storage-directory <string>Location of the storage directory on the local disk.
--nlog-extensions-directory <string>Location of the NLog extensions on the local disk.
--securestore-plugins-directory <string>Location of the secure store plugins on the local disk.
--is-external-storageIndicates whether the storage is external or not.
--namespace <string>The namespace where Automation Suite is deployed. The default value is uipath.
-h, --help Provides help for the upload command.
If you use an external storage configuration at the cluster level, you must indicate this by including the --is-external-storage parameter while using the command.
Storage upload considerations
The directory specified using the --storage-directory parameter must contain at least one subdirectory. All subdirectories are copied over to storage.
Files that are uploaded to the root folder using --storage-directory are ignored.
Internal storage
Subdirectories are copied directly to the bucket using the subdirectory name as the path.
External storage
  • If the subdirectory is named orchestrator-host, its contents are be copied over to the Orchestrator-Host path.
  • If the subdirectory is named orchestrator-<name>, its contents are copied over to the O<name> path.
  • In all other cases, the contents of the subdirectory are copied over to the <name> path.
Usage examples
uipathctl config orchestrator upload --storage-directory /path/to/storage/directoryuipathctl config orchestrator upload --storage-directory /path/to/storage/directory
Uploading NLog extensions to storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directoryuipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory
Uploading secure store plugins to storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directoryuipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory
Uploading files to external storage
uipathctl config orchestrator upload --is-external-storage --storage-directory /path/to/storage/directoryuipathctl config orchestrator upload --is-external-storage --storage-directory /path/to/storage/directory
Uploading nlog extensions to external storage
uipathctl config orchestrator upload --is-external-storage --nlog-extensions-directory /path/to/nlog/extensions/directoryuipathctl config orchestrator upload --is-external-storage --nlog-extensions-directory /path/to/nlog/extensions/directory
Uploading secure store plugins to external storage
uipathctl config orchestrator upload --is-external-storage --securestore-plugins-directory /path/to/securestore/plugins/directoryuipathctl config orchestrator upload --is-external-storage --securestore-plugins-directory /path/to/securestore/plugins/directory
  • Configuring Azure/Amazon S3 storage buckets
  • Uploading files to storage
  • Storage upload considerations
