- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Skipping host library creation
- Troubleshooting
Last updated Apr 22, 2026
Manifest configuration
Follow these steps to edit the Orchestrator manifest configuration:
Edit the
input.jsonfileFor details, see Configuring input.json.
Add or edit the desired settings in the
orchestratorsection. -
Run this command:
uipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestratoruipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestrator
Custom Orchestrator configuration
You can use this command to edit the Orchestrator custom configuration for both appSettings and NLog:
uipathctl config orchestrator
Custom Orchestrator scenarios
You can modify various Orchestrator parameters using uipathctl. This enables the following configuration scenarios:
