Last updated Jun 12, 2025
Running the support bundle tool
The Automation Suite support bundle tool collects application-level logs of UiPath® services and other software components, such as Istio, ArgoCD, etc. The Automation Suite support bundle tool also contains historical records you can use to analyze patterns when troubleshooting a problem. Detailed logs are particularly helpful when the potential root cause of an issue is not evident just by looking at the state of the cluster.
The Automation Suite support bundle tool is also needed when asking for guidance or a fix from the UiPath® Support team as they need it for analysis purposes.
Note:
The Automation Suite support bundle tool does not collect or store any PII or confidential data of you, your user, or your automation. UiPath® applications not not leak or log any confidential information in their records. At the platform level, the log collector is designed to mask any such critical information.
High-level summarized usage telemetry is also exported with this tool generating an XML file. This telemetry includes:
  • Robot execution duration per month by robot type.
  • Robot concurrency - the maximum number of robots that executed at the same time.
  • Metrics on jobs run, processes run, queue items, job failure rate, and users.
  • Environment information.
You can upload the XML file in the Customer Portal to share your high-level self-hosted usage telemetry with the UiPath Support team.
You can opt out of generating this summarized telemetry by listing service-metrics in the excluded list in Automation Suite 2024.10 and higher.
Generating the support bundle
To generate the support bundle, run the following command:
./uipathctl health bundle input.json --versions version.json./uipathctl health bundle input.json --versions version.json
This tool takes some time to gather and store all the logs in a temporary location on your local / management machine.
The following table lists the optional flags the support bundle tool support:
Flags
--output-dir string
Specify the directory to store the support bundle.
--namespace string
Specify the namespace where UiPath Automation Suite is deployed.
--include string
Specify additional components (comma separated) to include in the bundle (such as --include=historical-logs).
--exclude string
Specify components (comma separated) to exclude from the bundle (such as service-metrics).
--from YYYY-MM-DD
The start date to collect the historical logs in YYYY-MM-DD format.
--days int
The number of days from the start date for which to collect the historical logs.
--limit-bytes int
Limits the size of the logs of running pods by providing the integer value in bytes.
Note:
  • By default, if the --from flag is not specified, then the historical logs will be collected for the past 2 days starting from today, irrespective of the --days specified.
  • If the --from is specified and --days is not specified, then the historical logs will be collected for 2 days starting from the specified start date.
Automation Suite Support Bundle Structure
The .tar.gz archive contains following files and folders:
File/folder
current-logs
Contains the live logs (such as logs for current and previous instance of pods).
events.json
Contains the event descriptions from all the namespaces.
alerts
Contains the active prometheus alerts in the cluster.
namespace/resource/object.yaml
Contains the object descriptions for the server-preferred/custom namespace and cluster-scoped resources.
service-metricsContains high level usage telemetry stored in individual XML files.
