- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Disaster recovery: Active/Passive configurations
- Generating the configuration file using a wizard
- input.json example
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Last updated Nov 13, 2025
You can generate the input.json configuration file either manually or using the Automation Suite Installer Wizard. While the wizard offers a more user-friendly
approach, it currently does not accommodate all possible configuration scenarios.
In some specific instances, manual creation of the configuration file might be required. For details, see Configuring input.json.
To generate input.json using the Automation Suite Installer Wizard, take the following steps:
Any feature that is not available during the input.json configuration using the Automation Suite Installer Wizard, can be manually included after downloading the configuration file.
