Last updated Mar 9, 2026
Migrating between Automation Suite clusters
About the cluster migration
You can migrate from one Automation Suite cluster to another if you use the uipath namespace instead of a custom namespace and want to move from one Automation Suite flavor to another. We support the following scenarios:
  • Migrate from Automation Suite on Linux to a new installation of Automation Suite on EKS/AKS;
  • Migrate from Automation Suite on EKS/AKS to a new installation of Automation Suite on OpenShift;
  • Migrate from Automation Suite on OpenShift to a new installation of Automation Suite on EKS/AKS;
  • Migrate from Automation Suite on EKS to Automation Suite on AKS or from Automation Suite on AKS to Automation Suite on EKS.
Note that you can attempt to perform the migration operation multiple times with no impact on your existing cluster.
The following migration scenarios are not supported:
  • Migrating from Automation Suite on Linux to an existing installation of Automation on EKS/AKS or Automation Suite on OpenShift;
  • Migrating an Automation Suite on OpenShift cluster to Automation Suite on Linux cluster.
Process overview
Step
1.
Mandatory . Make sure you meet the migration requirements.
2.
Mandatory. Prepare the target cluster and the docker images for both source and target cluster.
Optional. If your deployment is offline or if you use a private OCI registry, make sure the required images are available.
3.
Mandatory. Start the migration, move the data, and run the Automation Suite installation.
4.
Optional . If AI Center is enabled on both the source and target clusters, migrate the skills.
For detailed migration instructions, see the Automation Suite on EKS/AKS Installation Guide.
Requirements
To migrate from an Automation Suite cluster to another, you must meet the following requirements:
  • Download the following artifacts:
    • uipathctl
    • versions.json
  • You must establish connectivity between the two environments.
  • You must have an external objectstore configured in your source cluster. If you use in-cluster storage, see Migrating in-cluster objectstore to external objectstore.
  • If you migrate from Automation Suite on Linux, the version of your source cluster must be 2022.10 or newer.
  • If you migrate to Automation Suite on OpenShift, the version of your source cluster must be 2023.10 or newer.
  • Offline-only requirements: You must hydrate the target cluster.
Data migration and responsibilities
Data
Migration mechanism
Status Responsibility
SQL
Retained
You have two options:
  1. Reuse the same databases for the new installation. Point the cluster configuration's SQL connection strings to the existing database server.
  2. Clone your databases and use the clones instead.
Customer
Docker registry
Not migrated
If you use a private registry, you must hydrate the target registry. If you use registry.uipath.com for the target cluster, no further steps are needed.)
Customer
FQDN
Required
You must choose a new FQDN for the new cluster. Optionally, you can revert to the previous FQDN if needed.
Customer
Certificates
Not migrated
You must bring certificates as part of the new cluster installation.
Customer
Cluster configuration
Not migrated
You must generate the new input.json applicable to the target cluster type (AKS or EKS).
Customer
Custom alerts and dashboards created by users
Not migrated
Post-migration, you must reconfigure any custom alerts in Alert Manager and Grafana dashboards.
Customer
Application logs / Prometheus streaming configuration created by users
Not migrated
You must reconfigure application log and Prometheus streaming.
Customer
Dynamic workloads
Depends on application
AI Center training jobs are lost; Skills are retained.
Skills (script needed to be executed after upgrade): UiPath®
Training jobs: Customer
Objectstore
External objectstore: Retained
For external objectstore, you have two options:
  1. Reuse the existing external object store and connect it to the new environment.
  2. Create a replica of your current object store and use this for the new setup.
: If you're using an in-cluster object store, you must perform a ceph-to-external migration before the upgrade.
Migrating from in-cluster to external objectstore: Customer
External objectstore: UiPath®
Insights
Retained
UiPath®
MongoDB data
Retained
MongoDB data is moved to the target SQL.
UiPath®
RabbitMQ
Not needed
UiPath®
Monitoring (data)
Not needed
Monitoring data does not apply to the new cluster.
N/A
Preparing the cluster migration
Preparing the target cluster
Important:
Do not run uipathctl manifest apply until you have completed Step 1 in the Running the cluster migration section. Running this command too early can result in configuration inconsistencies in the target cluster.
Note:
Do not modify the source cluster after starting the migration process.
To prepare the target cluster, take the following steps:
  1. Download the targeted version of input.json on the source cluster and generate the input.json file by running the following command:
    uipathctl manifest get-revision
For details, refer to the following diagram:
docs image 2. Based on the previously generated input.json file, modify the input.json file of the target cluster.
You must transfer the Orchestrator-specific configuration that includes the encryption key per tenant and Azure/Amazon S3 storage buckets settings.
Additionally, you must update the following components so that they reference the correct infrastructure in the target cluster:
  • External objectstore
  • SQL Server or PostgreSQL connection details
  • Redis cluster configuration
Note:
Dedicated Microsoft SQL Server and PostgreSQL for Process Mining Airflow database is the recommended option for version 2024.10.3 or newer.
If you migrate from a version prior to 2024.10.3, the generated input.json file for the target cluster does not contain the connection string for the Airflow PostgreSQL database. To use the latest version of Airflow, which requires PostgreSQL, you will need to manually add the sqlalchemy connection string template for PostgreSQL to the input.json file for the target cluster before migration. Postgresql_connection_string_template_sqlalchemy_pyodbc
postgresql+psycopg2://<user>:<password>@<postgresql host>:<postgresql port>/DB_NAME_PLACEHOLDER
  1. Validate the prerequisites in the target cluster by running the following command:
    uipathctl prereq run input-target.json --kubeconfig kubeconfig.target --versions versions.json
    Note:
    input-target.json is the input.json file corresponding to the target cluster.
To generate the kubeconfig file, refer to Generating the kubeconfig file. 4. If you are migrating from Automation Suite on Linux to a EKS/AKS deployment, you must put the source cluster in maintenance mode. For details, refer to Putting the cluster in maintenance mode. 5. Clone the SQL databases from the source deployment to the target deployment.
Hydrating the OCI-compliant registry registry without internet access
The migration process requires the latest uipathcore Docker image tag to be available for both the source and target clusters. If your source cluster is offline, make the image available by taking the following steps:
  1. Follow the steps to hydrate the registry used by the target cluster with the offline bundle in Option B: Hydrating the registry with the offline bundle.
  2. Copy the uipathctl binary and versions.json file on a VM with access to the source cluster.
  3. Run the following command:
    jq -r '.[][] | select(.name=="uipath/uipathcore") | .ref + ":" + .version' "/path/to/versions.json" > images.txt
  4. Seed the uipathcore image from the registry of the target cluster to the registry of source cluster:
    ./uipathctl registry seed --tag-file ./images.txt \
                --source-registry "target.registry.fqdn.com" \
                --source-password "target-registry-username" \
                --source-username "target-registry-password" \
                --dest-registry "source.registry.fqdn.com" \
                --dest-username "source-registry-username" \
                --dest-password "source-registry-password"
    Note:
    Make sure to update the command as follows:
    • Replace target.registry.fqdn.com, target.registry.fqdn.com, and target-registry-password with the proper values that correspond to the registry associated with the target cluster;
    • Replace source.registry.fqdn.com, source.registry.fqdn.com, and source-registry-password with the proper values that correspond to the registry associated with the source cluster.
Hydrating the OCI-compliant registry with internet access
If you use a private registry, you must seed it. For instructions, see Configuring the OCI-compliant registry.
To migrate to the target Automation Suite cluster, take the following steps:
  1. Execute the migration by running the following command:
    uipathctl cluster migration run input-target.json --kubeconfig kubeconfig.source --target-kubeconfig kubeconfig.target --versions versions-target.json
  2. Complete the Automation Suite installation on the target cluster by running the following command:
    uipathctl manifest apply input-target.json --kubeconfig kubeconfig.target --versions versions-target.json
Migrating the AI Center skills
The steps in this section are applicable only if you enabled AI Center on both the source and target clusters. Note that the instructions assume that AI Center on the target cluster points to the database containing the skill data for running the skills.
After completing the migration, you must sync the AI Center skills so that you can use them again.
Checking the skill migration status
You can use the following script to sync the AI Center ML Skill to the target cluster. The script triggers the sync in the background if no active sync is in progress.
The script syncs the skills in the background (async) and returns. The job ensures that the skills are deployed and updates the DB entry to reflect the current status.
uipathctl service aicenter sync-skills [skill_ids]
ParameterDescription
[skill_ids]The optional array of the skill IDs separated by space. If you provide the skill ID, then only those skills are updated; otherwise, all deployed skills are re-synced.
uipathctl service aicenter sync-skills 783273-3232-3232-323 32-32-323-3232
//this will only sync the skills with ID 783273-3232-3232-323 and 32-32-323-3232
To view the status of the AI Center ML Skill, run the following command:
uipathctl service aicenter sync-skill-status [skill_ids]
The command can return any of the following statuses:
  • InProgess - skill deployment is in progress.
  • Failed - skill deployment is failed.
  • OutOfSync - skill is available in the database; however, it has yet to be deployed.
  • Available - when the skills are deployed and available to consume.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
