Last updated Dec 15, 2025
Applying miscellaneous configurations
Note: Only apply the configurations in this section if you cannot provide admin privileges to the Automation Suite installer. If you can provide the required permissions to the installer, you do not need to apply the configurations in this section.
Creating a priority class
To create a priority class for UiPath® applications, take the following steps:
  1. Save the following configuration as a YAML file:
    apiVersion: scheduling.k8s.io/v1
    kind: PriorityClass
    metadata:
    value: 1000000
    preemptionPolicy: PreemptLowerPriority
    globalDefault: false
    description: "Priority class for uipath applications"---
    kind: PriorityClass
    metadata:
    value: 1000000
  2. Run the following command, replacing the <file_name.yaml> placeholder with the actual name of your YAML file:
    oc apply -f <file_name.yaml>oc apply -f <file_name.yaml>
Labeling the namespaces
To create namespace labels, run the following commands:
oc label namespace <uipath> uipath-injection=enabled
oc label namespace <uipath> istio-injection=enabledoc label namespace <uipath> uipath-injection=enabled
  • Creating a priority class
  • Labeling the namespaces
