Last updated Apr 15, 2026
Automation Suite products
Automation Suite lets you manage your self-hosted UiPath® platform as one product. However, not all of our self-hosted products are part of Automation Suite.
The following products are part of the Automation Suite bundle. You have the ability to enable or disable products at any time after their installation.
Some Automation Suite products have additional dependencies on each other, as listed in the following table:
Product Dependency
AI Computer Vision
  • AI Center
Apps
  • Data Service (for the Data Service integration)
Automation Hub
  • Orchestrator (for Automation Store, Studio, and Assistant integrations)
As Task Mining is not available in Automation Suite on OpenShift, the Automation Hub integration with Task Mining is also not available.
Automation Suite Robots
  • Orchestrator
Document Understanding
  • AI Center for AI Center-based projects
  • No dependencies for Document Understanding modern projects
  • Action Center (for human-in-the-loop validation)
Process Mining
  • Automation Hub (for sending ideas to Automation Hub, and for uploading app templates in Process Mining)
  • Notification Service (for Export)
  • Orchestrator (for Automation integration)
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
