- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Patch artifact download links
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
Download links for the artifacts required to apply patches to Automation Suite on OpenShift in Automation Suite.
This page provides the download links for the artifacts required to apply a patch.
2024.10.9 patches
This section provides the download links for the artifacts required for Automation Suite on OpenShift 2024.10.9 patches.
2024.10.9+patch1
uipathctl
To download uipathctl for Automation Suite 2024.10.9+patch1, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.9-patch1/uipathctl-2024.10.9-patch1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.9-patch1/uipathctl-2024.10.9-patch1-linux-amd64.tar.gz - Windows:
curl.exe -L -o uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.9-patch1/uipathctl-2024.10.9-patch1-windows-amd64.tar.gzcurl.exe -L -o uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.9-patch1/uipathctl-2024.10.9-patch1-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.9-patch1/uipathctl-2024.10.9-patch1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.9-patch1/uipathctl-2024.10.9-patch1-darwin-amd64.tar.gz
openshift.tar.gz
To download openshift.tar.gz for Automation Suite 2024.10.9+patch1, run the following command:
wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.9+patch1/openshift-2024.10.9+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2024.10.9+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.9+patch1/openshift-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2024.10.9+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.9+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.9+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.9+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.9+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.9+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2024.10.9+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.9+patch1/versions.json
2024.10.3 patches
This section provides the download links for the artifacts required for Automation Suite on OpenShift 2024.10.3 patches.
2024.10.3+patch2
openshift.tar.gz
To download openshift.tar.gz for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch2/openshift-2024.10.3+patch2.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch2/openshift-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch2/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch2/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch2/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2024.10.3+patch2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3+patch2/versions.json
2024.10.3+patch1
openshift.tar.gz
To download openshift.tar.gz for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch1/openshift-2024.10.3+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/openshift-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3+patch1/versions.json
2024.10.2 patches
This section provides the download links for the artifacts required for Automation Suite on OpenShift 2024.10.2 patches.
2024.10.2+patch1
openshift.tar.gz
To download openshift.tar.gz for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.2+patch1/openshift-2024.10.2+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/openshift-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2+patch1/versions.json
