- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring the Insights custom security context
- Configuring log rules
- Configuring appSettings
- Configuring NLog
- Troubleshooting
Configure the Insights custom security context for Chromium Linux SUID Sandbox feature support in Automation Suite.
The Insights application has multiple features that use the Chromium Linux SUID Sandbox. Thus, while the elevated access is not required for the installation of the Insights application itself, it is essential for specific feature functionality.
Save the configuration file as a YAML file and execute the following command. Make sure to replace the
<file_name.yaml>placeholder with the actual name used for your YAML file:oc apply -f <file_name.yaml>.allowedCapabilities: - SETUID apiVersion: security.openshift.io/v1 fsGroup: type: MustRunAs groups: [] kind: SecurityContextConstraints metadata: name: insights-scc readOnlyRootFilesystem: false runAsUser: type: MustRunAsRange seLinuxContext: type: MustRunAs supplementalGroups: type: RunAsAny users: [] volumes: - configMap - csi - downwardAPI - emptyDir - ephemeral - persistentVolumeClaim - projected - secretallowedCapabilities: - SETUID apiVersion: security.openshift.io/v1 fsGroup: type: MustRunAs groups: [] kind: SecurityContextConstraints metadata: name: insights-scc readOnlyRootFilesystem: false runAsUser: type: MustRunAsRange seLinuxContext: type: MustRunAs supplementalGroups: type: RunAsAny users: [] volumes: - configMap - csi - downwardAPI - emptyDir - ephemeral - persistentVolumeClaim - projected - secret -
Save the following in a file named
<file_name.yaml>to create a role to access the Security Context Constraint:kind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: insights-scc-role namespace: <uipath> rules: - verbs: - use apiGroups: - security.openshift.io resources: - securitycontextconstraints resourceNames: - insights-scckind: Role apiVersion: rbac.authorization.k8s.io/v1 metadata: name: insights-scc-role namespace: <uipath> rules: - verbs: - use apiGroups: - security.openshift.io resources: - securitycontextconstraints resourceNames: - insights-sccCreate a role to access the Security Context Constraint by executing the following command:
oc apply -f <file_name.yaml>. Make sure to replace the<file_name.yaml>placeholder with the actual name used for your YAML file. -
<file_name.yaml>to create a role-binding to bind the previously defined role to the Insights service account:kind: RoleBinding apiVersion: rbac.authorization.k8s.io/v1 metadata: name: insights-scc-rolebinding namespace: <uipath> subjects: - kind: ServiceAccount name: insightslooker-sa namespace: <uipath> roleRef: apiGroup: rbac.authorization.k8s.io kind: Role name: insights-scc-rolekind: RoleBinding apiVersion: rbac.authorization.k8s.io/v1 metadata: name: insights-scc-rolebinding namespace: <uipath> subjects: - kind: ServiceAccount name: insightslooker-sa namespace: <uipath> roleRef: apiGroup: rbac.authorization.k8s.io kind: Role name: insights-scc-roleCreate a role-binding to bind the previously defined role to the Insights service account by executing the following command:
Navigate to ArgoCD and disable Auto sync for Insights.
Update the security context for the Insights Looker, located within the Insights Looker statefulset. Add the
SETUIDcapabilities:capabilities: add: - SETUID drop: - ALLcapabilities: add: - SETUID drop: - ALL -
Rollout
restart statefulset:oc -n <uipath> rollout restart statefulset/insights-insightslookeroc -n <uipath> rollout restart statefulset/insights-insightslooker
