Last updated May 15, 2026
Remapping the organization IDs
To migrate from standalone Insights to Automation Suite, you must remap of the organization IDs in the following tables:
    [Id] [int] NOT NULL,
    [Key] [nvarchar](128) NOT NULL,
    [Name] [nvarchar](128) NOT NULL,
    [IsActive] [bit] NOT NULL,
    [IsDeleted] [bit] NOT NULL,
    [OrganizationId] [nvarchar](128) NULL,
 CONSTRAINT [PK_dbo.Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsintegrations].[TenantServiceIntegrations](
    [Id] [uniqueidentifier] NOT NULL,
    [TenantId] [uniqueidentifier] NOT NULL,
    [OrganizationId] [uniqueidentifier] NOT NULL,
    [ServiceName] [int] NOT NULL,
    [Status] [int] NOT NULL,
    [CreationTime] [datetime2](7) NOT NULL,
    [LastUpdatetime] [datetime2](7) NOT NULL,
 CONSTRAINT [PK_TenantServiceIntegrations] PRIMARY KEY CLUSTERED
 CREATE TABLE [insightspermissions].[GroupRoles](
    [GroupId] [uniqueidentifier] NOT NULL,
    [RoleId] [uniqueidentifier] NOT NULL,
 CONSTRAINT [PK_GroupRoles] PRIMARY KEY CLUSTERED
 CREATE TABLE [insightspermissions].[Groups](
    [Name] [nvarchar](max) NULL,
    [Email] [nvarchar](max) NULL,
 CONSTRAINT [PK_Groups] PRIMARY KEY CLUSTERED
 CREATE TABLE [insightspermissions].[Roles](
    [TenantId] [uniqueidentifier] NULL,
    [Resource] [nvarchar](max) NULL,
 CONSTRAINT [PK_Roles] PRIMARY KEY CLUSTERED
 CREATE TABLE [insightspermissions].[TenantGroups](
    [TimeProcessed] [datetime2](7) NULL,
    [LastUpdateTime] [datetime2](7) NOT NULL,
 CONSTRAINT [PK_TenantGroup] PRIMARY KEY CLUSTERED
 CREATE TABLE [insightspermissions].[Tenants](
 CONSTRAINT [PK_Tenants] PRIMARY KEY CLUSTERED
 CREATE TABLE [insightspermissions].[Users](
    [IsDeleted] [bit] NULL,
 CONSTRAINT [PK_Users] PRIMARY KEY CLUSTERED
 CREATE TABLE [insightsprovisioning].[TenantInstances](
    [ServiceType] [nvarchar](max) NULL,
    [State] [int] NOT NULL,
    [TenantName] [nvarchar](max) NULL,
 CONSTRAINT [PK_TenantInstances] PRIMARY KEY CLUSTERED
 CREATE TABLE [read].[HASHKEYS](
    [hashkey] [bigint] NOT NULL,
    [tenantkey] [nvarchar](128) NOT NULL,
    [tenantname] [nvarchar](256) NULL,
    [organizationid] [nvarchar](128) NULL,
    [status] [int] NULL
    [status] [int] NULL
[dbo].[Tenants]
[read].[HASHKEYS]
[dbo].[Tenants]
[read].[HASHKEYS]
Tip:
This is an example on how to update the tables:
--- Script to replace MSI organization ID with AS organization ID.
--- Please update the following DECLARE statements with your corresponding MSI org ID and AS org ID before executing this script.
DECLARE @msi_organization_id nvarchar(500) = upper('687db434-ce5c-4058-bc0b-3ed3fa23882b');
DECLARE @as_organization_id nvarchar(500) = upper('AA259F1A-5828-4608-AF71-27177A7831B8');
DECLARE @msi_resource nvarchar(500) = lower('insights/687db434-ce5c-4058-bc0b-3ed3fa23882b/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
DECLARE @as_resource nvarchar(500) = lower('insights/aa259f1a-5828-4608-af71-27177a7831b8/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
SELECT * FROM [dbo].[Tenants];
UPDATE [dbo].[Tenants]
SET OrganizationId = lower(@as_organization_id)
WHERE OrganizationId = lower(@msi_organization_id);
SELECT * FROM [insightsintegrations].[TenantServiceIntegrations];
UPDATE [insightsintegrations].[TenantServiceIntegrations]
SET OrganizationId = @as_organization_id
WHERE OrganizationId = @msi_organization_id;
ALTER TABLE [insightspermissions].[GroupRoles] NOCHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[GroupRoles];
UPDATE [insightspermissions].[GroupRoles]
ALTER TABLE [insightspermissions].[GroupRoles] CHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
ALTER TABLE [insightspermissions].[TenantGroups] NOCHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[TenantGroups];
UPDATE [insightspermissions].[TenantGroups]
ALTER TABLE [insightspermissions].[TenantGroups] CHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[Groups];
UPDATE [insightspermissions].[Groups]
SELECT * FROM [insightspermissions].[Roles];
UPDATE [insightspermissions].[Roles]
SET Resource = @as_resource
WHERE Resource = @msi_resource;
SELECT * FROM [insightspermissions].[Tenants];
UPDATE [insightspermissions].[Tenants]
SELECT * FROM [insightspermissions].[Users];
UPDATE [insightspermissions].[Users]
SELECT * FROM [insightsprovisioning].[TenantInstances];
UPDATE [insightsprovisioning].[TenantInstances]
SELECT * FROM [read].[HASHKEYS];
UPDATE [read].[HASHKEYS]
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
