- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Create priority classes and namespace labels in Automation Suite on OpenShift when admin privileges are unavailable.
Only apply the configurations in this section if you cannot provide admin privileges to the Automation Suite installer. If you can provide the required permissions to the installer, you do not need to apply the configurations in this section.
Creating a priority class
To create a priority class for UiPath® applications, take the following steps:
- Save the following configuration as a YAML file:
--- apiVersion: scheduling.k8s.io/v1 kind: PriorityClass metadata: name: uipath-high-priority value: 1000000 preemptionPolicy: PreemptLowerPriority globalDefault: false description: "Priority class for uipath applications"--- apiVersion: scheduling.k8s.io/v1 kind: PriorityClass metadata: name: uipath-high-priority value: 1000000 preemptionPolicy: PreemptLowerPriority globalDefault: false description: "Priority class for uipath applications" - Run the following command, replacing the
<file_name.yaml>placeholder with the actual name of your YAML file:oc apply -f <file_name.yaml>oc apply -f <file_name.yaml>
The priority class name uipath-high-priority is required and cannot be changed.
Skipping the priority class
If you do not want to create a priority class, set ignore_priority_class to true in the input.json file. Automation Suite then omits priorityClassName from all workloads, so no PriorityClass needs to exist on the cluster and you can skip Creating a priority class.
If you are installing without cluster roles, you must set ignore_priority_class to true, because creating a cluster-scoped PriorityClass is not possible in that mode. For details, refer to Granting installation permissions without cluster roles.
Labeling the namespaces
To create namespace labels, run the following commands:
oc label namespace <uipath> uipath-injection=enabled
oc label namespace <uipath> istio-injection=enabled
