- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions with cluster roles
- Granting installation permissions without cluster roles
- Installing the External Secrets Operator
- Running uipathctl
- Setting up the required resources
- Prerequisite checks
- Output example: prerequisite check
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- 500 errors and rate limiting on S3 requests in ODF
- External Secrets troubleshooting
- Configuring CSI driver tolerations for ODF 4.20
- Temporal as a Service troubleshooting
Example output from prerequisite checks in Automation Suite on OpenShift.
The following example shows the output you may get after checking the infrastructure prerequisites as part of the Automation Suite installation. For details, refer to Prerequisite checks.
ℹ️ [empty-app] Creating Argo CD application for component empty-app...
ℹ️ [empty-app] Waiting for Argo CD application for component empty-app to synchronize...
Ran cluster/ checks...
Ran ORCHESTRATOR(CLASSIC_FOLDERS) checks...
✔ successful
Ran local/ checks...
Ran ARGO checks...
✔ successful
Ran CONNECTIVITY checks...
✔ successful
Ran DEPLOYMENT_PROFILE checks...
✔ successful
Ran DNS(FQDN=APPS.<FQDN>) checks...
✔ successful
Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...
✔ successful
Ran INGRESS checks...
⚠ [INGRESS]
⚠ [UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
Ran NAMESPACE checks...
✔ successful
Ran NETWORK-POLICIES checks...
✔ successful
Ran NODE(CPU >= 8, RAM >= 16G) checks...
⚠ [NODE(CPU >= 8, RAM >= 16G)]
✔ [LIST_NODES] Listed 4 nodes
✔ [AT_LEAST_ONE_NODE] At least one node found
✔ [CPU_USAGE] Node os7140768-7db2g-master-0 has 37.50% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-master-0 has 46.35% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-master-0 has 0.00% of pods in use. Number of pods: 0.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 12.50% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 13.64% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 6.25% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 8.30% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 18.75% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 11.11% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 0.80% of pods in use. Number of pods: 2.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
⚠ [AS_ROBOTS_NODE_EXISTS] No dedicated node found
Ran OSS(COMPONENT=CERT-MANAGER) checks...
✔ successful
Ran OSS(COMPONENT=GATEKEEPER) checks...
✔ successful
Ran OSS(COMPONENT=ISTIO) checks...
✔ successful
Ran PERMISSION checks...
✔ successful
Ran PRIORITYCLASS checks...
✔ successful
Ran REGISTRY_PULL checks...
✔ successful
Ran RESOURCE checks...
✔ successful
Ran SECRETS checks...
✔ successful
Ran STORAGECLASS(NAME=STORAGE_CLASS) checks...
✔ successful
Ran STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA) checks...
✔ successful
Ran nodes/ checks...
Ran CONTROLPLANECONNECTIVITY checks...
✔ 4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=BA) checks...
Ran OBJECTSTORAGE(PRODUCT=DATASERVICE) checks...
Ran OBJECTSTORAGE(PRODUCT=ORCHESTRATOR) checks...
Ran OBJECTSTORAGE(PRODUCT=PLATFORM) checks...
Ran OBJECTSTORAGE(PRODUCT=TESTMANAGER) checks...
Ran REDIS(PORT=6380) checks...
Ran SQL(PRODUCT=ASROBOTS, TYPE=ADO) checks...
Ran SQL(PRODUCT=AUTOMATIONHUB, TYPE=ADO) checks...
Ran SQL(PRODUCT=AUTOMATIONOPS, TYPE=ADO) checks...
Ran SQL(PRODUCT=BA, TYPE=ODBC) checks...
Ran SQL(PRODUCT=DATASERVICE, TYPE=ADO) checks...
Ran SQL(PRODUCT=INSIGHTS, TYPE=ADO) checks...
Ran SQL(PRODUCT=NOTIFICATIONSERVICE, TYPE=ADO) checks...
Ran SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO) checks...
Ran SQL(PRODUCT=PLATFORM, TYPE=ADO) checks...
Ran SQL(PRODUCT=TESTMANAGER, TYPE=ADO) checks...
Checks complete!
✔ successful
Ran ARGO checks...
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
⚠ [INGRESS]
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
Checks complete!
